20 Most Recent Juki DDL-8300 Questions & Answers
2answers
Thread fraying on certain vinyl material, why?
u need a silicon based nylon thread and a larger needle. needle may be getting hot too depending on thickness of work. spray some silicon on upper thread.
12/24/2023 4:02:20 PM • Juki DDL-8300 • Answered on Dec 24, 2023
2answers
Re: Juki DLL5550N-7 with SC-1 CA. Could you help
If your machine is industrial you will need to look at the clutch linings
4/28/2023 7:37:12 PM • Juki DDL-8300 • Answered on Apr 28, 2023
Juki DDL8300N sewing machine replacement needles.
Question edited for clarity. Question moved from Gaming Consoles to correct category. You can get them from all these places. The top link is the number 1 supplier 'Sewing Parts Online'. https://www.google.com/search?q=Juki+DDL8300N+sewing+machine+replacement+needles ..
6/13/2022 3:04:36 PM • Juki DDL-8300 • Answered on Jun 13, 2022
5answers
How to fix timing on a juki ddl-555
Hi, if your ddl-555 sewing machine the needle doesn't grab the string from the top and bottom; and it can't sew the fabric. Do you know what to do/
8/25/2017 2:58:18 AM • Juki DDL-8300 • Answered on Aug 25, 2017
HELP PLEASE!!
I am slightly familiar with older sewing machines but not modern machines. It is a long time since I've seen my machines. If your presser foot has a wide slot it is clearly possible to use it for zig-zag sewing. If the machine is capable of zig-zag or swing needle sewing, it is sometimes possible to swing the needle and fix it to the left or right and fix it in that position. I suggest you check in your machine instruction manual. Perhaps the presser foot you are using is unsuitable for your machine...
5/13/2017 2:22:56 AM • Juki DDL-8300 • Answered on May 13, 2017
Manual Guide for Juki Frou Frou HZL-11
Visit us at www.ifixmachine.com
8/23/2016 11:45:17 AM • Juki DDL-8300 • Answered on Aug 23, 2016
The stitch length dial is not working. Stitches are huge and the dial feels looser than usual.
Selector is either worn or broken. Probably best to take it for service. ...
1/20/2016 5:08:17 PM • Juki DDL-8300 • Answered on Jan 20, 2016
Where is the fuze of HZL-5700
The fuse is typically in the electrical box where the on/off switch is .
9/18/2014 10:42:19 PM • Juki DDL-8300 • Answered on Sep 18, 2014
My JUKI DDL-8300N has locked
if its not mechanical the thread has bound up the hook. spray hook all over with oil and let sit for a day then use hand wheel to force hook to turn, u will not damage machine. gp back and forth.
6/14/2014 9:20:48 PM • Juki DDL-8300 • Answered on Jun 14, 2014
The race and needle of my Juki 8300N is jammed.
douche the hook with oil wait a day and use hand force to get machine to turn. u have thread deep inside hook and its binding the machine. u can spray with wd-40 too but use alot and let it sit.
6/14/2014 9:12:08 PM • Juki DDL-8300 • Answered on Jun 14, 2014
I have been sewing on my Juki DDL-555-4 for nearly
change needle the root of almost all problems!!!
6/14/2014 9:09:03 PM • Juki DDL-8300 • Answered on Jun 14, 2014
Does a loose belt cause a high pitched squeek
usually the other way around. belt may be worn too. u can adjust tension by screws under machine that hold motor.
6/14/2014 8:59:07 PM • Juki DDL-8300 • Answered on Jun 14, 2014
How can I get spare
hi there
if you mean mechanic parts i have parts list for DDL5550-7 it's same parts but if you need electronic parts for control box tell me the model for control box. now email me i can send parts list to you
best regards
ashraf abozid
[email protected]
4/28/2014 2:50:50 AM • Juki DDL-8300 • Answered on Apr 28, 2014
My machine wont sew
machine out of time or wrong needle. most problems with machines involve the needle.
4/11/2014 8:54:04 PM • Juki DDL-8300 • Answered on Apr 11, 2014
Frequently, while I am sewing, the needle hits something below the guide plate and gets stuck. I have to remove the guide plate and then the needle will release. What is the problem with my machine?
If the needle gets stuck with no thread, The needle is hitting something. Could be needle not up all the way or something needs adjusting. If it gets stuck with thread. It is probably an upper thread tension or threading issue.
4/8/2014 10:05:31 PM • Juki DDL-8300 • Answered on Apr 08, 2014
Juki ddl 5550-6
Hi there, can you tell me your control box model? some model of control include variable resistor to adjustment the speed for thread trimmer. a waiting your answer about control model and i will help you. thanks ASHRAF CAIRO - EGYPT [email protected]
1/8/2014 5:41:48 PM • Juki DDL-8300 • Answered on Jan 08, 2014
Difficultiy in understanding japness on machine
Hi there, just send your email and i will send to you user manual for DDL-5550 , it's same DDL8300 JUKI machine. regards ASHRAF CAIRO - EGYPT [email protected]
1/7/2014 6:19:01 AM • Juki DDL-8300 • Answered on Jan 07, 2014
132 questions posted
Top Juki Sewing Machines Experts
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Juki Sewing Machines
Most Popular Question
juki ddl 5550 6 e7 error code
  • Sewing Machines
