20 Most Recent
Juki DDL-8700 Questions & Answers
GUR Enterprise UK LTD - Sewing Machines in England
GUR Enterprise UK LTD is a leading company that offers sewing machines in England. Our online store holds a large range of sewing equipment and accessories to help sewers, seamstresses and sewing enthusiasts in England create outstanding artwork. https://www.sewingmachinesinengland.co.uk/
SC-810 ERROR E071
hi there
concern ERROR ( E071 ) means Disconnection o motor output connector.
please check the motor output connector for loose connection and disconnection. otherways means IPM module is defective.
if you need more help please contact me.
BEST REGARDS
ASHRAF ABOZID
[email protected]
Does The Juki 8700 sewing machine have a automatic Thread Triimmer
final answer about this questionhello allin case of normal machine you need to add many parts to convert from manual to auto thread trimmer ( need electronic motor with control - auto thread trimmer mechanic components - hook - feed dog - etc.... ) it's very difficult to change from normal to auto thread trimmer.best regardsashraf abozid
10/29/2022 11:58:29 PM •
Juki DDL-8700
Answered
on Oct 29, 2022
Error 924
hi there
regarding Error E924 at JUKI control it means Motor driver failure ( Motor driver has broken.) or you can first check motor connection if connected secure or there's lose connection. other ways try to change motor with new one or check control box only with working machine to confirm Error coming from motor or control box.
BEST REGARDS
ASHRAF
CAIRO - EGYPT
[email protected]
Checking the oil level on a juki ddl-8700
Hi there, gently tilt the head of your machine back and rest it on the white peg thing at the back. Inside you should see lines on the back side of the oil pan...min and max. If you are somewhere in between, all good. If not, add more. NOTE: always use clear machine oil. Any other stuff will stain your work. Hope this helps, have a great day
Stretch stitch juki 8700
Hi there, no you cannot do a stretch stitch on the ddl-8700. It only has on stitch and it is a straight lockstitch.
Some times Error-2 & some
hi there
1- your control box model is SC-500 not SV500, juki didn't made sv never ever
2- there is no error 2 just error 3 and error 4 both means there's problem with synchronizer which installed behaind handwheel first try to clean it by dray spray maby there's some oil or dust arround it. if error still coming change the senchronyzer with new one
best regards
ashraf abozid
[email protected]
I have a Juki ddl
Your table sounds like it was cut for a different machine..You might be able to move your motor over to where the belt will come straight down from the handwheel. There is some adjustment that can be made with a wrench on the large nuts that hold the motor up to the table. Good luck.
Elna 704 DEX needle bar broke
I looked everywhere on line that I could think of and couldn't find one. I have had luck looking for other parts I needed by watching ebay selling a model for parts. My go to mechanic is in Cleveland OH at the Geo. E. Johnson Co. Ask Herb or Jerry if they can order the part and have it sent to you.800-729-6341.
How can I run pressure foot selector switch
Pressure on foot is regulated by the screw on the top of the machine directly above the pressure foot bar. Make sure your lever on back of machine is down, then turn the screw by hand, left for less pressure and to the right for more pressure.
Has anyone adjusted the presser foot inside the machine? That can throw it off or sometimes you need to look under the machine head into the oil pan to make sure there isn't something stuck and holding the pressure up from there.
Is this a new or used machine? Does it have enough oil in the pan?
