20 Most Recent Juki MO-644D Mechanical Sewing Machine Questions & Answers
3answers
Juki Sewing machine DDL-555. After 4-5 hours use feed not moving
Sounds like as the machine builds up friction from extended use, some vital part is lacking lubrication and is seizing up. A good service person will remove ALL of the covers and thoroughly air clean and oil every moving part. Sometimes these dry points are hard to find and patience is required.
You can get a sewing machine oiler with a long applicator and put a drop of oil on anything that moves, but over oiling can be messy.
1/18/2019 5:35:59 PM • Juki MO-644D... • Answered on Jan 18, 2019
Juki ddl 555 knee lifter is not lifting the foot. How can I fix it?
I imagine that it is the mechanical knee lift that you actually lift with your knee? Sometimes the screw that holds the knee lift rod comes loose a little and starts to slide in the holder. Sit on the floor where you can see the underneath of your table and use a wrench or vise grip to loosen the bracket that holds your knee lift bar with the pad on it. Move the bar to the left and retighten the screw and I think you will be ok. Sometimes if there is too much oil in your pan or you have moved the machine and some of the oil spilled out, a little oil gets out of the pan onto the bar and makes it start to slip. If that doesn't work we'll try something else.
2/3/2017 3:14:41 AM • Juki MO-644D... • Answered on Feb 03, 2017
3answers
Threading a juki ddl 5530
Go to this link and you will find how to thread your machine.
6/2/2016 12:46:04 AM • Juki MO-644D... • Answered on Jun 02, 2016
2answers
I just bought a new Juki serger MO-644D and I
I found the instruction manual for your serger on eBay. It is item # 160454752052
4/6/2015 4:12:24 AM • Juki MO-644D... • Answered on Apr 06, 2015
2answers
2nd needle/4th thread - threading confusion
With some sergers, but not many (singer 14u64 comes to mind), the top of the stitch will be an overedge that mates with the right needle thread, and the left needle thread will appear as a separate straight stitch. When you look at the underside of the stitch, the overedge will go all the way over to the left needle (the full width of the stitch). This is normal if you have this type of machine. Another stitch some sergers do (2/4 thread sergers) is a 2 thread chain thal looks like a lone straight stitch on both sides, and a 2 thread separate overedge.
As far as the threading of the takeup, it totally depends on your model. Always post your model number when you have questions as sergers vary greatly in design.
4/6/2015 4:02:32 AM • Juki MO-644D... • Answered on Apr 06, 2015
Bosch Ahs 7000 pro-t what makes the blades come off the gearbox?
Attachment method is not correct. Owner's manual shoud tell you how to do it properly. No Owner's manual, try manualslib.com if they have it. or the MFG website.
3/27/2015 10:07:16 PM • Juki MO-644D... • Answered on Mar 27, 2015
Hello, I have an older Juki serger and it's
Have you installed new needles recently? Also, sometimes old thread causes a problem,. Or the needle size/thread size are not compatible.
3/25/2015 4:21:46 AM • Juki MO-644D... • Answered on Mar 25, 2015
The rotary spindle has jammed
Here is the Manual: JUKI MO 644D Instruction Manual
2/15/2015 1:22:37 PM • Juki MO-644D... • Answered on Feb 15, 2015
Rethreading my juki overlock
threading industrial overlockers can be very tricky do you not know anyone who ever worked one in a factory because showing is much easier than telling
2/9/2015 12:57:41 PM • Juki MO-644D... • Answered on Feb 09, 2015
2answers
Whats the differance between a overlocker and a
A overlock machine helps you clean finish the seams. You can do many things with a overlock It can cut your sewing time down. The sewing machine is good for many thing too,Mostly the construction of the garment. I have three machines. A indstrialstraight stitch, a home machine and a overlock.Al for different tasks.
1/2/2015 3:01:48 AM • Juki MO-644D... • Answered on Jan 02, 2015
Does the Juki DL-555 sew leather?
ordinary drop feeds are not suited for sewing leather,ideally a needle feed or machine with a walking foot mechanism is best suited.if you are stuck with this machine only,there are a couple of things which may help.on some of the juki ddls there is an adjusting screw and locknut on top and in the middle of the arm of the machine .turn needle by hand wheel to bdc and loosen this screw and turn clockwise slowley! this will raise the presser foot very slightly,so when the feed dog is at tdc it can improve the feeding . spear point needles are reccommended also. one other idea,but you need a qualified mechanic to do this is to alter the feed timimg slightly on the eccentric on the top shaft.as the needle is entering the fabric,slow the timing down so the needle enters the leather just as the material starts to move. hope this helps! cheers kev w 07725903110
11/19/2014 12:44:37 PM • Juki MO-644D... • Answered on Nov 19, 2014
2answers
I have a brand new Juki MO-50e and the threads are loose on the back of the fabric, how do I fix this?
  1. . re-thread your machine with a rainbow of colors. (important that you remove the existing threads if you are not sure it is threaded properly.) make sure you are lifting the presser foot while rethreading.
  2. Sew a good 6 inches.
  3. Look to see which threads are the offenders and tighten the co-responding tension knobs a little.
  4. Sew another 6 inches. Examine the result. Adjust tension again if needed.
  5. Work this way until you have the stitch balanced.
  6. Finally when your stitches are perfect. clip the threads at the spools in back. And tie on the coordinating colored thread for your fabric.
Get used to this procedure since it is common to have to adjust tensions when you change fabric. Good luck!
11/5/2014 4:31:00 PM • Juki MO-644D... • Answered on Nov 05, 2014
2answers
Do you know where can I get a user manual for my
hi there
please send your email address i will send to you service manual for this machine.
best regards
ashraf abozid
[email protected]
10/13/2014 8:04:02 PM • Juki MO-644D... • Answered on Oct 13, 2014
I have juki 7923. It is cover stich. ones in wile the looper is not caching what shoud i doo
Hii try to attach PDF file for how to adjust top cover thread spreader and how to adjust looper timing but the upload only support gif-jpg-png file,please email me to send PDF file to you.BEST REGARDS
6/13/2014 5:28:41 AM • Juki MO-644D... • Answered on Jun 13, 2014
Changing blades
http://www.jukihome.com/downloads/manuals/MO655_InstructionManual.pdf p. 46 of this pdf. Top blade rarely needs replacement, but lower blade works like this. I highly recommend taking good closeup photos of the machine, front, back and side view, of the knives before you start swapping them out. See, e.g.: http://www.picturetrail.com/sfx/album/view/24107038
4/29/2014 12:41:40 AM • Juki MO-644D... • Answered on Apr 29, 2014
I have Juki ddl5550 model cs-4002-6 that the
It might be your connections inside, Juki is a great mechine I would fix it.
call 303 770 6321
AAAA TEVA
4/28/2014 2:47:00 AM • Juki MO-644D... • Answered on Apr 28, 2014
0answers
Juki MO-644D Mechanical Sewing Machine Logo
131 questions posted
Top Juki Sewing Machines Experts
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Juki Sewing Machines
Most Popular Question
brand new juki mo 50e threads loose back
  • Sewing Machines
