Xerox 3610 printer
Print #10 envelopes on a Xerox 3610 printer
Solution : Print on Envelopes
You can print envelopes from the Bypass Tray only.
Guidelines for Printing Envelopes
To Load Envelopes in the Bypass Tray:
Phaser 3610 Support Drivers
NOTE: If you do not load envelopes in the Bypass Tray right after they have been removed from the packaging, they can bulge. Flatten them to avoid jams.
NOTE: To navigate through the menu, use the Up or Down arrow buttons.
SOURCE: Can't print envelopes
Solution Title:
How to print on COM10 envelops from the Bypass tray (PCL6) using a Windows 2000 O/S
Resolution/
Solution
Fixed! Did not fix.
Resolution Role: Fix
Critical Message: The Envelope must be placed in the Bypass Tray face down (flap side up) and Long Edge IN.
In Microsoft Word (Word 2000)
Within the WorkCentre Pro 123/128 print driver
After opening up the print driver [<Start>, <Settings>, <Printers>, double-click on the WCP 128 PCL6 driver], click on Printing Preferences under the General tab.
Set the following features as follow:
In Microsoft Word under Envelopes and Labels, Click <Print> to send the information to the printer.
Note: This setup represents one way of printing envelopes. Other ways setting up some features in a different manner will work as well.
Solution v1.3.20.0
312637.How to Print on COM10 Envelops From the Bypass Tray (PCL6) 2006-04-05 21:57:29
SOURCE: How to print C5 & C4 envelopes
Here is the answer from Xerox.
> Support & Drivers > DocuColor 12 Copier/Printer Support > Search Results
Solution: Printing on Envelopes is Not Supported
Make Printable
Email this page
CAUTION: Printing on envelopes may cause damage to the copier / printer.
SOURCE: Envelopes all come out of the printer wrinkled
Open the back of the printer. You will see 2 little blue levers on either side. Put them in the opposite direction, that is, if they are up, snap them down. I dont know the mechanics of this, but it worked for me.
SOURCE: Printer Error When Printing Envelopes
I had the same problem with my 7260 and I finally changed the paper type from automatic to plain paper. Go to either Properties or Preferences in your printer set up window. Somehow this turns off some sort of sensor. It might work for you, too. To the person who is using the Hallmark program, that is where I first encountered the problem, I then tried to print an envelope from Word and the same error message came up. I found this solution online from someone using a three in one printer/fax/copier so I tried it and it worked for me, too! I hope this helps......
SOURCE: Unable to print #10 envelopes on my Xerox
Although you can lie to the 76XX series machine and get it to print on envelopes, the machine clearly shows that it does not take envelopes on the tray pictures. "Only C4 (229 x 324 mm / 9 x 12.7 in.) and C5 (102 x 229 mm / 4 x 8.7 in.) sized envelopes can be used with this printer; Number 10 envelopes are not supported. Attempting to use any other envelope sizes in this printer could result in jams. or damage to the printer. Do not use envelopes other than what is supported. "
Insert them Face up, flaps closed, leading edge to the right. When it asks, tell it envelopes, and give the size.
In the Envelopes section, under Mailings, Options, choose face up, and the 5th picture. It should work, but the envelopes sure get wrinkled.
