20 Most Recent
Xerox WorkCentre 7232 VSE All-In-One Laser Printer Questions & Answers
Erroe/fault 093-311
fault Code 093-311: Rotary Assembly Failure
Solution : Power the Machine Off and On
CAUTION: Wait at least 60 seconds between powering the machine off and then on again; otherwise, damage to the machine and the hard drive may occur.
- Press the power switch to the [O] (off) position.
NOTE: The machine will remain on for approximately 10 seconds while storing files and preparing for shutdown, and then will power off completely.
- Wait 60 seconds, and then press the power switch to the ['] (on) position.
Que signifie le code 089-311 sur workcentre7232
The problem is the ibt belt sensor is not reading the silver patches on the edge of the ibt belt. They are either scratched or the sensor is dirty or faulty. Replace patches and clean or replace ibt belt sensor.
Error code 093-311
The Rotary Assembly Failure indicates that for some reason, bad developer unit or mis-aligned has caused the Rotary ***'y to jam. This requires removing the right side and front side covers, Power supply and the black protective shroud along with each developer/drum unit from the device before uninstalling/reinstalling the Rotary ***'y. You will definitely need the service manual to know how to take this apart and put it back together safely.
