I just installed a new black ink cartridge and now allit does is spit out blank pages - even when i shows something in the quque
SOURCE: Aligning printer after new ink cartridge inserted
SOLUTION:
Start the cartridge alignment by performing a series of button presses from the front panel of the product.
CAUSE:
This can occur if the cartridge alignment is canceled or times out without a valid print cartridge alignment stored in memory.
SOURCE: printer spits out blank page
This should solve this problem if you haven't already. It's real simple.
SOURCE: HP 2410 photosmart will not align after changing ink cartridge
I have the same problem. I can't tell you how to fix it as my printer will no longer align, but to bypass the align page message to get to setup you have to hold down the setup button then press up.
SOURCE: HP L7590 black ink printing poorly even with new HP cartridge
I have had the same problem It is the print head not the cartridge If your printer is still under warranty have the printhead(s) replaced if not Open the unit where the print heads are and hold the OK button for 5 seconds. The Print head carriage will move to the left
Carefully remove the KY (Black & Yellow) Print head with a cotton swab and alcohol clean the contacts and replace the printhead. If this does not work remove the printhead and then with a spray bottle spray the nozzle area on the bottom (DO NOT TOUCH THE NOZZLES AS THEY WILL BE DESTROYED) HP techs have told me this will void any warranty so act accordingly I use a printhead cleaning solution available from most any online ink supplier
Replace the printhead after it has dried out (less than a minute). The printer will then go through an alignment cycle and should print I had to do this several times before the print head performed as it should
SOURCE: installed new hp black cartridge 56 ink but won't print
it shows if your using refill cartridge. & if you r using refill cartridge clear cartridge sensor with soft hands your problem would be resolved.
