20 Most Recent HP DeskJet 6540 InkJet Printer Questions & Answers
Go to system settings and select the 'Printer' option.
Right-click on the printer and enable the 'Use Printer Online' function.
Cancel all the printing jobs till that moment and redo the process.
Sometimes the 'Printer Offline' message occurs due to a 'Job Stuck' issue.
Check all network connections and functions.
Be sure the network interfaces work properly.
Turn the printer off and on to see whether the device is working properly.
HP DeskJet 6540... | Answered on Jan 21, 2019
How do I print a test page without the printer being hooked up to a printer ?
HP DeskJet 6540... | Answered on Jun 16, 2017
HP Deskjet 6540 will not support Wireless network connectivity.
Standard Connectivity:
Universal Serial Bus (USB) cable 2.0 compatible. The HP Deskjet 6540 printer includes two USB ports. One port is located at the back of the printer and one is located at the front for easy access.
HP DeskJet 6540... | Answered on Sep 11, 2016
The printer automatically aligns the print cartridges after a new print cartridge is installed. You can also align the print cartridges at other times to ensure optimal print quality.
To align print cartridges:
1. Load letter-size or A4-size plain white paper in the In tray.
2. Open the printer Toolbox.
3. Click Align the Device.
4. Click Align , and then follow the onscreen instructions
Here are directions for how to open the printer Toolbox, in case you don't know:
The printer Toolbox contains a number of useful tools to enhance the printer performance.
Use the printer tools to perform the following tasks:
• Set the Auto-off function
• Clean the print cartridges
• Align the print cartridges
• Calibrate color
• Print a test page
• View estimated ink levels
To use the tools, open the Printer Properties dialog box, click the Services tab, and
then click the Service this device button.
AND, in case you don't know how to open the Printer Properties dialog box, here you go! :
The Printer Properties dialog box is also referred to as the Printer Preferences dialog box.
Opening the Printer Properties dialog box
Follow these steps to open the Printer Properties dialog box:
1. Open the file that you want to print.
2. Click File , click Print , and then click Properties or Preferences.
Good luck to you! I hope this helps.
HP DeskJet 6540... | Answered on Aug 08, 2014
black ink cartridges have blocked replace with new
HP DeskJet 6540... | Answered on Jul 27, 2014
HI,
Change settings from an application for current jobs (Windows)
To change the settings
1. Open the document that you want to print.
2. On the File menu, click Print, and then click Setup, Properties, or Preferences.
(Specific options may vary depending on the application that you are using.)
3. Change the settings that you want, and then click OK, Print, or a similar command.
More info read page no.33.
http://h10032.www1.hp.com/ctg/Manual/c01325559.pdf
Thanks,
HP Printer Support
HP DeskJet 6540... | Answered on May 30, 2014
Runaway print jobs are always a pain! First, power off your printer to stop it from wasting paper. If the power button doesn't work, pull its plug. That will stop the printing for now but your print job will probably restart when the power is resumed.
Whether you are using a PC or Mac, documents that you send to the printer are managed by a printer management service which is responsible for printing documents in the correct order and handling any printer problems that occur. When the printer is turned off, any documents you print will be saved (queued) for printing when the printer starts again. To fix your runaway printing problem you simply need to delete the copy of your large document that is still queued for printing.
On Windows you will see a small icon on the toolbar at the bottom right of your screen that looks like a printer. When you click on the icon you should see a window appear which has the name of your printer in the title bar (e.g. HP Deskjet) and a list of any documents waiting to be printed. To delete a print job, simply right-click on the document name in the list and select "Cancel". When asked "are you sure you want to cancel the document" click on YES and the document will be deleted from your printer queue. Repeat this for all documents in the list until it is empty, then you can restart your printer.
The process on a Mac is similar and even easier since you will see a bouncing printer icon with an exclamation point on it on your toolbar. Click on that icon to see the print queue, click on the document you want to delete and press the DELETE key to remove it.
HP DeskJet 6540... | Answered on Apr 12, 2014
Your Printer head need cleaning, try doing a self cleaning or change you ink, hope this helps.
HP DeskJet 6540... | Answered on Jan 24, 2014
HP DeskJet 6540 InkJet Printer Logo
130 questions posted
Clive
Clive
View Most Popular
DeskJet HP
  • DeskJet HP
Most Popular Question
use printer offline error processing
  • Office Equipment & Supplies
