SOURCE: GE Profile Spectra Broiler not lighting
I'm not an expert, and I'm reading you're post while looking for a solution for our oven, so this is in no way should be taken as a suggested solution, it isn't!!!....here it is anyway: I think it might be a bad ignitor, I have replaced a couple on our stove and both times we had exactly the same symptoms you're experiencing, I think also we're in line for a third ignitor for this "less then 10 year old Magic Chef". Good luck
SOURCE: GE Range Spectra oven not working
F2 is an indication of an oven temperature sensor problem. Usually this is a problem with the oven sensor itself, or the relay contacts on the Electronic Range Control (ERC) board. If you had a close lightening strike, I would suspect that the contacts on the ERC are probably bad. It probably wouldn't hurt to replace the oven sensor as well. I hope this helps you.
SOURCE: oven not working
Sounds like the oven control which is the clock is bad. The relay for the bake element has probably gone bad and will need to replace the control. You should check continuity on the bake element. If it shows resistance then it is ok. Also, on some models the overlay for the oven control is a separate part. If it is you will need to buy it also.
SOURCE: oven AND broiler do not work but self-clean does
good day, i suggest to check all inside wiring and switch. thanks
SOURCE: caloric gas stove prestige series
to jenna 12 Does your stove have a stop and start timer? When you set your clock you may have inadvertantly moved the stop or start time on that timer. Check them, if they have knobs for setting the stop and start time, make sure the pointer is pointing to the current time and that the knob is popped out and not stuck in. when you have it right both the stop and the start knob should be out, not pushed in. They will pop out when you turn them to the current time.
These timers allow you to start something cookin at a time delayed several hours. this means they will not allow the oven to come on until it hits that time that you may have set in error.
If your stove has a digital stop and start timer check each one so that both show the current time, then your oven should light.
