Hi Anonymous, this is AP!
I understand you are interested in the self-clean process for your Frigidaire slide in range, model FES355ASF. Start by removing all excess spillovers in the oven cavity before starting the self-cleaning cycle. To clean, use hot soapy water and a cloth. Large spillovers can cause heavy smoke or fire when subjected to high temperatures. Clean any soil from the oven frame and the door liner, but avoid cleaning the oven door gasket. These areas heat sufficiently during self-cleaning cycle to burn soil on. Clean with soap and water. Remove the oven racks, broiler pan and insert, all utensils and any foil. These items do not withstand high cleaning temperatures
Make sure the clock shows the correct time of day. Push the CLEAN button "---"will appear on display. Push the up arrow button until "3:00" appears for a 3 hour clean cycle or push the down arrow until "2:00" is displayed for a 2 hour clean cycle. Once the time is selected and released CLn will appear on the display. The door will then automatically lock and the LOCK indicator light will flash. Do not open the door while the indicator is flashing, usually about 15 seconds. The LOCK display will stay until the cleaning cycle is complete or cancelled, and the oven temperature has cooled to a safe temperature.
In the event you need to stop the cycle at any point, simply push the CLEAR OFF button and the door will automatically lock once the oven has cooled, usually about an hour.
Best of luck,
Hold the door closed and apply slight pressure to the door, then start the cleaning again, it will lock the door shut, if you get the error again then there could be a problem with the lock, could be dirty and stuck from grease or malfunctioned.
But contact the company, you can go to there support page on their website and let them know the problem and they should help resolve the problem.
ok, this is an internal fault that concerns the internal circuitry in this oven. due to the sophisticated nature of this electric oven, it will require specialattention form a service tech. (f9). major fault within the circuitry of the oven. possible control board failure.
As copied from the manual.
Setting a silent control panel
When choosing a function, a beep will be heard each time a pad is pressed. If desired, the control can be programmed for silent operation. Press and hold (start/time) . After 7 seconds, the control will beep once. This will block the controls from sounding when a pad is pressed. To return the sound, press and hold (start/time) again for 7 seconds until the control beeps once
NOTE!
The OVEN indicator light on the electronic display will turn ON and OFF when using the Bake feature and during preheat. This is normal and indicates that the oven is cycling to maintain the selected baking temperature. When the preheat indicator light turns OFF, your oven is ready.
Hi im an appliance tech and i had the same problem its not the EOC other words control board its actually the speed bake swith its stuck in the on position that why you get a stock keypad error code either f1 or f11 replace that switch or disconnect it and im positive that this will solve it .
Send it back and get the correct one. It can't be the same part number if the connections are different. Your old one may have features that his new one doesn't. The one less wire may just be a shared return, but the stove might be needing individual returns. If it is an updated replacement (the listing sometimes says 'compatible with' or 'replaced by', or 'alternative part'), it should come with a wiring schematic.
Please always include full 'make MODEL (what it is)'.
Fixya Expert 'Jorgie the Appliance Guy' will have the answer if it is a shared return but he will need the model number. Edit your post and add it.
No orifice for the oven jet? All work on gas appliances needs to be done by a certified gas technician. Somewhere, normally just behind the knob, there is an adjusting screw (certainly for hobs). The flame must be high enough that it can't blow out. The standard test is the slam the oven door, with your kitchen windows closed and then again with them open. Help in the link, but also the pressure from the tank _at_ the range should be checked.
https://www.google.com/search?q=oven+flame+adjustment
This is so confusing
You say
"The oven and broiler elements are not working"
Then you say
"Everything works except the burners'.
so nothing works? No oven/broiler elements and no burners? It make me wonder what the 'everything' is that works? The clock? The oven light?
Sounds like the main house breaker has flipped. On my older GE stove from the 1980s there are glass screw in fuses hidden below the controls and above the hobs. You undo the switch bezel for the oven light and the switch bezel for the rotisserie and pull the panel forward exposing 8 fuses. If all yours blew, it would be very strange!
Click comment under my answer and also under Vince's and we will get you Fix-Ya.
