If your Activa 210 sewing machine is not performing the reverse stitch function, there could be a few possible reasons for this issue:
1. Incorrect stitch selection: Ensure that you have selected the correct stitch that includes a reverse stitch. Some stitches, particularly decorative or specialty stitches, may not have a reverse option. Check your machine's manual to identify the stitches that offer reverse functionality.
2. Mechanical issue: There could be a mechanical problem preventing the reverse stitch function. Check if there is any lint, debris, or thread buildup in the reverse stitch lever or mechanism. Clean the area carefully with a soft brush or use compressed air to remove any obstructions that may be hindering the reverse stitch mechanism.
3. Stitch length setting: Verify that the stitch length is not set to zero. If the stitch length is at its minimum, it may prevent the reverse stitch function from engaging. Increase the stitch length slightly and try again.
4. Incorrect machine operation: Ensure that you are following the correct procedure to engage the reverse stitch. Typically, you would need to press and hold down a lever or button while sewing to activate the reverse stitch. Refer to your machine's manual for the specific instructions on how to engage the reverse stitch.
If none of the above steps resolve the issue, it is recommended to contact a professional sewing machine technician or the manufacturer's customer support for further assistance. They will be able to provide specific guidance and help diagnose any potential mechanical issues with your Activa 210 sewing machine.
Follow the instructions below if the machine is stuck on reverse
1. Turn the machine off.
2. The reverse button may be stuck in the reverse position.
- Press and release the button to see if it releases and allows the machine to sew in the forward direction.
3. Check that you have selected the correct stitch.
Some stitches will sew in reverse and some will sew reinforcement stitches.
4. Make sure you are holding down the button while sewing 3-5 stitches.
If you do not hold the button down while sewing reinforcement stitches, the needle will sew in the same place.
5. Remove bobbin and clean the bobbin area. Reinstall bobbin.
6. Turn the machine off and hold the reverse button for 3-5 seconds.
7. Turn the machine back on and test to see if the machine will sew forward.
If the problem persists, Contact Customer Support
Depends on the make & model of your machine. Would be best to consult the owner's manual. Mechanical and computerized machines also vary. Mechanical machines usually have a stitch length lever that, when pushed all the way up, will reverse stitch, or there is a button usually marked with an R or an arrow. Computerized machines usually have a button marked by a U-shaped arrow.
Of course, if you have a vintage sewing machine, it may not even have a reverse stitch. Instead, to sew in reverse, one would have to sink the needle into the fabric, raise the presser foot and swivel the fabric 180 degrees, drop the presser foot and stitch.
To find a copy of the owner's manual, search the internet for:
Manufacturer + Model + the word "Manual"
Depends on the make and model of your machine. Some newer machines do have a securing stitch. Before that option was built in to new machines, sewists would simply decrease the stitch length for a couple of stitches or else do a couple of reverse stitches at the beginning or ending.
Try turning the flywheel and operate the reverse lever at the same time. Some machines need to be at a certain point in the stitch cycle for the reverse lever to be used.
Shorten your stitch in reverse the machine can't do a stitch that long in reverse. Also google your make and model machine and the word Manual so you can properly learn to use the machine safely.
My machine was also not sewing in reverse and stuck in a basting stitch. It was a simple fix. Unscrew the plate and remove any pins stuck in there. All fixed
Be sure you are in the correct stitch pattern...if you are on a buttonhole stitch or a stretch stitch it normal for the machine to sew backwards. Be sure your length is to the right of 0 and not in a strtch stitch model or buttonhole mode.
