LG LMV1630ST Microwave Oven Logo
A
Anonymous Posted on Mar 14, 2014
Key pad dont work - LG LMV1630ST Microwave Oven
christiaan saayman
Level 2:
Habit-Forming:
New Friend:
  • Expert 132 Answers
  • Posted on Sep 27, 2018
christiaan saayman
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
132
Questions
6
Helped
43487
Points
310
Replace transformer on pc board
Galanz microwave Code 310
This how i fixed with mi open hand i hit the number pad , 3 times hard like i dont care anymore and yeaaaaa it work like new again
Hotpoint microwave key pad parcially not working
The pads actually share some of the same lines inside the touch pad. There are silver oxide traces inside there. If a trace inside breaks, it depends on which trace breaks as to what pads dont work. If a trace that is common to say pads 1,3,5,7 you would lose function of those pads. 1.....2.....3.....4......5....... it is sort of set up like that inside wher eone connects to another and so on. So lets say a line between 2 and 3 breaks then you would lose pads 3, 4, 5 and any others on that same line. Will have to replace touch pad, cannot repair.
1helpful
Buttons on microwave dont work
The problem is in the keypad control board, this part alone is at least $97.00
1helpful
The # 1 button and # 2 button dont work on the key pad. Cant set any time using the 1 and 2.
Sounds like a replacement control panel will be required. They do fail and usually are not a serviceable part.
Call an engineer for fitting.
1helpful
Several buttons on key pad of microwave are not working
Steam got into key pay. Sometimes it will dry out. Take key pad apart and try to dry with a hair dryer, not to hot, you just want to blow condensation out of it. If this does not work, key pad needs to be replaced. The problem is they cost as much as a new microwave.
1helpful
Buttons on number pad dont work , except one
HI, the key pad or, touch pad is defective. you will need to replace it asap if possible.
These key pads run about 130 dollars tops. contact Panasonic for this part.
Sharp microwave model R-395F(S) bought in NZ. 1100W about 30litre. Problem from new, display weak but main problem as some buttons work some don't work and you have to push stop a few times before it...
Hi Lindsay
Sound like you need a new key pad if you have some handy man around you you can replace it, It require dismantle the front key pad remove electronic part and clean then reinstall properly the key pad itself about $40.00 Aus
Let me know if you need part number for that key pad
Cheers
Night Light
Your Control Key Pad is a circuit with each function and button a switch. The pad on your TV Remote, and Telephone is no different. The Key Pad is failing, It will only get worse. Determine if you can replace the Touch (Key) Pad. Not the Control Circuit, just the Touch Pad. Sometimes you can get it seperate. It connects by a Flex Cable to the Control Circuit.
Top LG Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
