20 Most Recent
LG LMV1680 Microwave Oven Questions & Answers
Very loud motor sound -
The magnetron in the microwave has failed, "heats food" and some cases gives off an odor that stands out. To repair the oven will approach the price of a new one
We had a bad storm
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Oven is not heating
heatman101
fjfkj
Is not heating up
Well that's not good news! I suspect the Magnatron ( engine) is at fault here. The cost of replacement often exceeds the value of the unit. Considering these days a microwave can be bought new from about a $100.00 depending on size. Second hand ones can also be bought from about $30 with a warranty and a pre sales check.
Magnatron replacement is about $250 + labour of about 2 hrs
Please rate my help++++Thanks for using FIXYSA
My new LG solardome MA3884vc overheats melamine plate @30 seconds
If your LG Solardome microwave oven is overheating a melamine plate within 30 seconds, there could be a few potential issues at play:
- Power Settings: Check to see if the power settings on your microwave are too high. If it's set to a high power level, it can cause certain materials, like melamine, to overheat quickly. Try reducing the power level and see if that helps.
- Plate Material: Melamine plates are not suitable for use in microwave ovens as they can overheat and potentially release harmful chemicals into your food. It's recommended to use microwave-safe dishes made of glass, ceramic, or microwave-safe plastic.
- Microwave Performance: If the microwave is consistently overheating items within such a short time frame, it might indicate a malfunction. In this case, it's best to contact LG customer support or a certified technician to inspect and repair the microwave.
- Placement and Usage: Ensure that the plate is placed centrally on the turntable and not touching the sides of the microwave. Also, avoid using the microwave for extended periods without interruption, as this can cause overheating.
- Testing with Different Materials: Try using a microwave-safe ceramic or glass plate to see if the issue persists. If other materials heat up quickly as well, it could indicate a problem with the microwave itself.
