20 Most Recent LG Over-the-Range Microwave Questions & Answers
IFB microwave ( which i have 30sc2) are directly imported from china, i find in many friends who bought this device are having a lot of problems, the microwave have major defect in the thin flim front membrane panel and the pcb board, after spending a 5 times with various issue the cost came to Rs 8700.00 not forgetting the repair done within warranty period, luckily i found a person who modified the front panel , replacing with MICRO SWITCH, the pcb was also modified relay, latter rotary switch front panel of Samsung and pcb was installed in place of old, now it had solved the problem, now use it only in convection and grill for nutrition reason. would like to help any one who has this problem.
LG... | Answered on Apr 18, 2019
It seems there is something wrong either with the builtin controls or the buttons. It needs to be examine by a professional.
LG... | Answered on Oct 31, 2017
It is energy saving mode, its a bad design because it doesn't let you keep the clock displayed. Only will stay on 5 min
LG... | Answered on Dec 02, 2016
high voltage diodes or the high voltage transformer deffective.
LG... | Answered on Nov 11, 2016
Faulty door interlock or controller
LG... | Answered on Oct 17, 2016
The problem is on the circuit board, and I regularly repair these by mail.
Feel free to e-Mail me at pupista@gmail.com for details and free advice.
LG... | Answered on Sep 28, 2016
If you wish to get some details; check the site linked here. Pull up older posts.......
http://electro-medical.blogspot.com/
LG... | Answered on Jun 07, 2016
disassemble and replace tape or glue
LG... | Answered on Feb 12, 2016
If too much current passes through the microwave circuitry, the line fuse will blow. If the line fuse blows, the microwave won't start. To determine if the line fuse is at fault, use a multimeter to test it for continuity. If the fuse does not have continuity, replace it. In addition, you should investigate and resolve the problem that caused the fuse to blow. If you don't resolve the underlying issue, the new fuse will blow too. (Caution: The microwave oven can store thousands of volts of electricity in its high voltage capacitor, even after the microwave oven has been unplugged. Due to the potential for electric shock, it is extremely dangerous to replace the electronic components in a microwave. Only a licensed technician should replace the line fuse.)
LG... | Answered on Feb 11, 2016
the part is just a small motor. really easy to replace. and the part is inexpensive maybe under $20. but for a service person to come out and do the repair is pretty expensive in most places. at least $100. but if anyone you know is at all handy, they could do it easily for you. a couple of screws remove the bottom on the microwave. a couple of screws hold the motor, and two quick connect wires. thats it. good luck. (if this is just a tabletop microwave maybe a new one would be a better option. usually under $75)
LG... | Answered on Dec 24, 2015
All microwave ovens have microswitches to confirm door open/closed. Many have several, and a bad switch can cause all sorts of strange issues. My ovens have 4 such switches, and I've had several go bad. You have to open the oven up to see which you need, measure them, and replace the bad ones. The good news is that the switches aren't expensive.
LG... | Answered on May 26, 2015
You are looking either a High Voltage Transformer or a Magnetron. These are only sold directly to authorized service technicians as the voltage that runs through them is extremely dangerous to work with.
I would find a local repair shop in your area that works on Microwaves and take it to them.
LG... | Answered on Apr 28, 2015
The touch pad could be the problem. Touch pads are notorious for going bade. the door interlock switches could also be a problem. Check to see if all the pads work if they do it could be just the start pad that is bad.
LG... | Answered on Mar 14, 2015
Sad to say you need to contact the company . if you had problem right away why did you keep it ?
LG... | Answered on Jan 13, 2015
LG Over-the-Range Microwave Logo
122 questions posted
Top LG Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
LG Microwave Ovens
  • LG Microwave Ovens
Most Popular Question
lg lmhm2237bd microwave clock stay
  • Microwave Ovens
