20 Most Recent LG LMV1650ST Microwave Oven Questions & Answers
0answers
Samsung SMH9207ST WILL NOT TURN OFF
dirty on/off key. open and clean with a brush
6/8/2014 12:04:34 AM • LG LMV1650ST... • Answered on Jun 08, 2014
0answers
0answers
The microwave unit in my Thermodore CMT231 has
When you say it stopped working , you mean no lights or display etc. Then that can be a fuse but fuses blow for a reason. Find the reason if the fuse blew.
10/15/2013 12:06:37 PM • LG LMV1650ST... • Answered on Oct 15, 2013
When I open the door the fan starts and the light is on
If it's cooking when the door is opened, that's dangerous, but any defect needs to be addressed!I would suspect a problem with a door switch or mount. The door switch help file is here.If we knew what your model number was, we could possibly give you a link to the service manual.So we can only give you generic help.See these links before proceeding: http://031d26d.namesecurehost.com/mwd/safety.txt http://031d26d.namesecurehost.com/mwd/disassembly.txt Here's a YouTube video showing how to remove a typical over the range control panel assembly in under 5 minutes. If this is not enough to help, then please post a new help request with your full model number from the tag in or on the oven, and detailed symptoms.
1/30/2013 4:21:42 AM • LG LMV1650ST... • Answered on Jan 30, 2013
Will not heat up food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
9/1/2011 2:43:10 AM • LG LMV1650ST... • Answered on Sep 01, 2011
My microwave intermittently (1) hums but
heatman101 ][
8/13/2011 1:22:51 AM • LG LMV1650ST... • Answered on Aug 13, 2011
Hello, I can't locate my lg
You can find your manual HERE
The parts breakdown can be found HERE
3/26/2011 2:21:15 PM • LG LMV1650ST... • Answered on Mar 26, 2011
I have a lg lmv
if it does not power up, then it means its having a power problem. it might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
This unit must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the unit turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter in order to test the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Take care.......
3/19/2011 9:21:13 PM • LG LMV1650ST... • Answered on Mar 19, 2011
Door
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We have the service manual for that model on our site at
http://www.microwavedisplay.com/LMV1650_sm.pdf
We're happy to help and we appreciate your thoughtful rating of our answer.
1/3/2011 11:48:29 PM • LG LMV1650ST... • Answered on Jan 03, 2011
The door on the microwave
You can ordre separate parts for the door or the whole door.
In searching for the service manual for this model, LG points us to the manual for model LMV1645 (here), so while it will be useful in disassembly and repair, I would contact Encompass here or call them toll-free at 866-779-5835 to be sure you get the right part numbers.
Good luck with it.
8/19/2010 2:48:51 AM • LG LMV1650ST... • Answered on Aug 19, 2010
I have an LG LMV1650ST, the heat stopped working
Look, i dont like to tell a non tech how to repair thir own microwaves as there are dangerous voltages sitting there that havent discharged.Step 1, if the magnatron goes faulty, it normally makes a loud growling sound and blows the fuses.So hopefully it isnt faulty. Most of the time i find the HVdiode damaged and to be safe, i replace the 1 micrifarad capacitor.as well. Before you replace that even, normally there is a single fusible wire that runs from the transformer to the cap. If that fuse is blown, have it replaced. Ask a friend who has a little electrical knowlege to help you please.
8/10/2010 11:36:18 AM • LG LMV1650ST... • Answered on Aug 10, 2010
LG LMV1650ST handle falling off and needs to be replaced
The lower door handle bracket broke and I'm trying to find out how to replace it. I already have the new bracket.
7/16/2010 8:02:00 PM • LG LMV1650ST... • Answered on Jul 16, 2010
LG LMV1650ST Microwave Oven Logo
43 questions posted
Top LG Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
LG Microwave Ovens
  • LG Microwave Ovens
Most Popular Question
when open door fan starts light
  • Microwave Ovens
