We are getting the following message on the control panel. 81 0180 EI0 1 Error. Can you help explain what this means.
We are unable to print anything from networked computers.
The problem is usually caused by printing a PDF file with fonts/page size/ page formating errors which will cause the printer to display the 49.3048 error. The only way to use the printer is to POR or recycle the power and delete the print job from the server or spooling device and cancel it on the printer before the offending command is issued to the printer again. You can try updating the firmware to the latest version 46.140.5 from the HP website. MIke L.
I cant able to print back to back in hp laser jet 4600dn laserjet printer but it is printing through onthe system what the problem pls suggest me
Try to remove the jet direct card into another slot. If that does not work you need to purchase a new jet direct card.
HP Color Laserjet 4700n giving 49.3048 Service Error Message. Will not print any sent document. After restart, I was able to print configuration page, File Directory Page and Event Log Page. But will not print from any anything sent from any computer. Thanks Delaw
4700 hp error 49.3048
