My copier shows an error c0f32 after i clean the photo-conductor unit,any solutions?
Replace the drum and developer
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: develop ineo 161
open then close the front door -> the display show " CHANGE DRUM ? YES/NO " -> press yes on the board
SOURCE: Service Call error C0F32 in Konica minolta copiers
Since you did not include the Model number I will suggest the following:
This code means pretty much the same on all Konica/Minolta machines.
The ATDC or automatic toner density control has experianced a problem. Have you run the copier out of toner by chance?
You can try resetting this code to see if it comes back. If it keeps coming back then you are going to need the process unit serviced. Or depending on the model you can replace the "Imaging Unit" yourself.
SOURCE: how to solve bizhub 211 code error c0650
C0650 Faulty scanner home position sensor • The scanner home position
sensor (PS100) does not go from HIGH to LOW when the
scanner motor (M4) is energized for a given number of steps
after the sequence to bring the scanner back to its
home position has been started at the end of a scan
motion and during re-shading. • The scanner home position
sensor (PS100) does not go from LOW to HIGH when the
after a scan motion has been started at the end of a
PS100 home check scan
Gently swing the IU in the horizontal
direction to even out developer
in the Developer Mixing Chamber.
Clean ATDC Sensor (UN1).
Change ATDC Sensor (UN1) and
developer.
Change Master Board (copier:
PWB-A).
