20 Most Recent Toshiba e-Studio 161 Copier Copier Questions & Answers
2answers
Paper Jam
Sak passe!! you did not specify where the jam is?
7/4/2018 5:08:57 PM • Toshiba e-Studio... • Answered on Jul 04, 2018
0answers
After replacing developer for Toshiba 161 copier the signal refused to clear please help me
in old model copier you must adjust td sensor after replace developer. in toshiba 161you must:
1.press0and5 in numeral keys
2.turn on machin .aj mode shown
3.inter 200 by numeral keys and start or interput
Machin work for minutes .
Press interput ana turn off then on
11/8/2016 7:56:35 PM • Toshiba e-Studio... • Answered on Nov 08, 2016
What is this serial number?
on the back of machine like sabc 123456
11/4/2016 11:57:54 PM • Toshiba e-Studio... • Answered on Nov 04, 2016
2answers
Toshiba e-Studio 166 copier
how to reset tonner
8/18/2016 9:35:06 AM • Toshiba e-Studio... • Answered on Aug 18, 2016
On which window cn i use my toshiba estudio 161 printer
windows xp and vista only.
8/16/2016 1:18:00 AM • Toshiba e-Studio... • Answered on Aug 16, 2016
Model DP-1620. How can I download driver?
http://www.toshiba.ca//
7/19/2016 2:28:14 PM • Toshiba e-Studio... • Answered on Jul 19, 2016
Hi sir my Toshiba e-Studio 161 Copier error show H and 2
Thermistor open Reset heater error
7/19/2016 2:14:29 PM • Toshiba e-Studio... • Answered on Jul 19, 2016
While using the machine after a sudden power failure is that the H2 is the solution
Thermistor open. Reset the heater error.
7/19/2016 2:13:50 PM • Toshiba e-Studio... • Answered on Jul 19, 2016
In toshiba 161 photocopier f5 error indicats
http://www.copytechnet.com/forums/toshiba/79285-e-studio-161-f5-02-error-code.html
3/15/2016 9:19:14 PM • Toshiba e-Studio... • Answered on Mar 15, 2016
Error code H4
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Toshiba studo120 H4 error code
12/4/2015 2:55:53 PM • Toshiba e-Studio... • Answered on Dec 04, 2015
0answers
How do I set for a4 copy?
  1. Toshiba e-STUDIO161 Operation Manual - ManualsLib
    www.manualslib.com > ... > Toshiba Manuals > Printer > e-STUDIO161 Toshiba e-STUDIO161 Service Manual 124 pages ... User safety This Toshiba digital plain paper copier does not produce laser radiation hazardous to the user.
7/21/2015 5:19:09 PM • Toshiba e-Studio... • Answered on Jul 21, 2015
2answers
Toshiba e studio 166 like printer dont work
connect the copier to computer through USB cable, turn it on, then re-install software it will recongnize the port and machine itself.
5/26/2015 9:54:02 AM • Toshiba e-Studio... • Answered on May 26, 2015
2answers
Toshiba e-studio 161 developer
Sir, i added new toner and new developer but my printout is dull. What i do?
5/26/2015 4:49:48 AM • Toshiba e-Studio... • Answered on May 26, 2015
My printer copy is black in the paper what is the problem
CHECK THE EXPOSURE LAMP ON THE SCANNER.
4/10/2015 3:05:43 PM • Toshiba e-Studio... • Answered on Apr 10, 2015
Toshiba e-Studio 161 Copier Copier Logo
231 questions posted
Top Toshiba Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Grand Canyon Tech
Grand Canyon Tech
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Office Equipment & Supplies
Most Popular Question
inter coin
  • Office Equipment & Supplies
