20 Most Recent Konica Minolta Di1610 Copier Questions & Answers
3answers
When i turn on my
Front cover is placed on front of machine. Should be some tabs near top, or on either side. If not, use finger nails or thin sturdy tool or object to pop open. Should be very little resistance. Don't force it. Should see all the guts of copier or whatever it may be. Usually can see the paper stuck in there. Good idea to unplug and try pulling jammed paper out. Close and restart.
2/3/2018 7:53:42 PM • Konica Minolta... • Answered on Feb 03, 2018
Develop ineo 163 maintenance call 2
this is PM call, some items may have reached to its life. consult Service Representative.
12/14/2016 2:04:02 PM • Konica Minolta... • Answered on Dec 14, 2016
Develop inea 164 Photostat machine error c2558
replace the developer and the drum, run required test and ensure counters are cleared Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
7/9/2016 9:38:59 PM • Konica Minolta... • Answered on Jul 09, 2016
Develop copier machiene model ineo 164 showing display call service 2558
Replace the developer after clearing counters and before running developer charge Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
6/25/2016 2:55:55 AM • Konica Minolta... • Answered on Jun 25, 2016
Error code 2558
sir Have you replaced the developer??? Did you clear the developer counter??? Before you remove old developer. Did you run the required Developer Charge after new developer was installed??? Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
6/25/2016 2:38:14 AM • Konica Minolta... • Answered on Jun 25, 2016
Develop ineo 164 copier call service 2558
6/25/2016 2:37:56 AM • Konica Minolta... • Answered on Jun 25, 2016
6/25/2016 2:36:20 AM • Konica Minolta... • Answered on Jun 25, 2016
Errro c- 6102 konica minolta model 363
something is wrong with the scanner located under the big glass the scanner is what move when you use the big glass or sens a document thru the doc feeder then the scanner move back towards the small glass Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/15/2016 9:37:24 PM • Konica Minolta... • Answered on Jan 15, 2016
HOW TO SOLVE C0F32 ERROR CODE ON DEVELOP INEO 161?
replace the drum and developer Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/15/2016 9:05:20 PM • Konica Minolta... • Answered on Jan 15, 2016
Caution maintenance call(m2) develop ineo 163
Replace the developer and drum and clear required counters Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/9/2016 10:58:13 AM • Konica Minolta... • Answered on Jan 09, 2016
Machine trouble service call cc153
No such code please chk again. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
12/29/2015 9:19:13 PM • Konica Minolta... • Answered on Dec 29, 2015
How to fix job concelled on ineo develop 164
What is wrong with the job? or just resend the job Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
12/28/2015 7:38:59 PM • Konica Minolta... • Answered on Dec 28, 2015
Error c2558 develop ineo 164
need a developer Dv-116 or try to -menu quick setting << quick setting <> (service mode) go to function and press auto TCR adjust press ok or need developer Dv-116
8/26/2015 7:12:53 AM • Konica Minolta... • Answered on Aug 26, 2015
I need the Konica Minolta
The ip address is provided by your it department if you do not have an it department then you can select an ip address that is not being uesd example 192.168.1.200 this lus the sub net mask standard sub net mask 255.255.255.0 needs to be put in the network section of the machine then you can go to the c: prompt on your computer type in ping then the ip address you put into the machine you should get 4 replys and no drops then you will also need to load the print driver for the machine onto your computer
5/23/2015 4:56:03 AM • Konica Minolta... • Answered on May 23, 2015
Paper jam on Bizhub c224e
Where is paper jamming, bypass tray, 1 or 2 draw, exit, finisher? Inside the machine? When you print or when you copy or both? Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
12/30/2014 4:36:42 PM • Konica Minolta... • Answered on Dec 30, 2014
2answers
Inncorrect tc type
incorrect type of toner cartridge was installed. only use the toner cartridge that has been manufactured specifcally for this machine.
12/30/2014 6:19:10 AM • Konica Minolta... • Answered on Dec 30, 2014
6answers
Problem with Konica Minolta Di1610
Incorrect T/C type means that toner cartridge have not good contact with toner chip, is good to clean this chip, or contact inside magine is not good. Change toner cartridge and if that problem remain, its needed replace contact unit on machine
12/30/2014 5:58:11 AM • Konica Minolta... • Answered on Dec 30, 2014
6answers
Konica Minolta Di470 With Pi4700e Password
sysadm
5/15/2014 11:17:13 AM • Konica Minolta... • Answered on May 15, 2014
C13F0 error code
C0954 mafunction
5/15/2014 10:52:28 AM • Konica Minolta... • Answered on May 15, 2014
Konica Minolta Di1610 Copier Logo
83 questions posted
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Konica Minolta Office Equipment & Supplies
Most Popular Question
develop ineo 161
  • Office Equipment & Supplies
