Computers & Internet Logo
s
suchita abhimanyu bedre Posted on Feb 22, 2014
Getting command line option syntax error while installing matlab2011
David Erickson
Level 1:
New Friend:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Apr 10, 2014
David Erickson
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
9
Questions
0
Helped
1254
Points
17
2 Related Answers
Anonymous
  • 8619 Answers
  • Posted on Dec 27, 2008
SOURCE: I get a window saying Command line option syntax error.
Hi! I think you are using internet explorer 6.0 then upgrade it to internet explorer 7.0 or later. Delete temporary internet files, History and Cookies from internet properties in control panel. If this is not the case try uninstalling and re-installing internet explorer.
And if still unsuccessful then using Mozilla Firefox web browser will certainly solve your concern.
You can download Mozilla Firefox from the following link -
http://www.mozilla.com/en-US/firefox/3.1b1/releasenotes/
Anonymous
  • 11896 Answers
  • Posted on Oct 13, 2009
SOURCE: can you correct my error message? command line
In computer science a syntax error ( IPA: /ˈsɪntæks ɛrə(ɹ)/ ) refers to an error in the syntax of a sequence of characters or tokens that is intended to be written in a particular programming language.
For compiled languages syntax errors occur strictly at compile-time. A program will not compile until all syntax errors are corrected. For interpreted languages however syntax errors cannot be detected until runtime and it is not necessarily simple to differentiate a syntax error from a semantic error.
A syntax error may also occur when an invalid equation is entered into a calculator. This can be caused, for instance, by opening brackets without closing them, or less commonly, entering several decimal points in one number.
copy and paste this link in your internet address bar for more information:
http://www.google.com/search?q=SYNTAX+ERROR&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a
feel free to ask any other questions
1helpful
What does error syntax mean
You enter a command. It is like an English sentence with a syntax (correct structure). If the structure of the command is wrong, you have a syntax error. You could use a minus - sign, instead of a change sign (-) that constitutes a syntax error.
Cannot view my own website. it reads: "Parse error: syntax error, unexpected $end..." in my index.php file. HELP
Syntax errors are the most common problem for developers. A single syntax error can cripple even the best applications and websites. You can correct syntax errors easily once you find them. Typical errors include missing commas, semicolons and parenthesis. Debuggers are available in many software development kits to aid you in the location of syntax errors. However, you can find and correct syntax errors manually as well. Learning how to correct syntax errors is an essential part of being a software developer.
Locate the syntax error manually. Step through each section of your code. Most code will be sectioned off into groups or functions. Carefully proof your code. Be sure to pay close attention to how lines are grouped. A common syntax mistake is incorrect grouping.
For instance, if you have an If Else statement embedded in another If Else statement, be sure the embedded statement is surrounded by a separate set of parenthesis or brackets, depending on your language. Double-check notes sections. Notes are only for the developer to see. However, if the syntax isn't correct, the notes may become part of your application, which may not agree with existing code. Ensure the syntax around your notes is correct. Run a debugger if possible. This will make locating errors much easier. A debugger will be found under a menu such as Debug, Run or Tools or as part of your SDK's toolbar. Allow the debugger to run. Errors will be listed at the bottom or right side of your screen. Many debuggers will highlight possible errors in your code as well. A line number, along with the possible error, will be listed in the error message. Locate your syntax error if the debugger isn't correct. Sometimes a debugger will show you where your application stopped working correctly. The syntax error itself may be above or below the line listed in the debugger message. Check all syntax within the surrounding area, especially within the line's function. Run your application after correcting the syntax error. Check every possible function of your application to ensure it works correctly. If you find a problem, double-check the syntax in your code that surrounds the problem area. For instance, if your application has a log-in screen that isn't accepting passwords correctly, check the code for the log-in screen. Remove Syntax Error syntax error typically occurs when the Web page you are loading causes a script error in the browser. This is caused by incorrect code that displays an error message or results in a Web page that does not load correctly. You can remove a syntax error by making a change to the settings of your Web browser. Common Web browsers that can experience this type of error include Internet Explorer, Mozilla Firefox and Safari.
Double-click the "Internet Explorer" icon to open the program. Click the "Tools" drop-down menu and select "Internet Options." This will display the Internet Options window. Go to the "Advanced" tab and scroll down to the "Browsing" section. Remove the check from the box for "Disable script debugging (Internet Explorer)," "Disable script debugging (Other)" and "Display a notification about every script error." Click the "Apply" button to save the changes. Click the "OK" button to close the Internet Options window. Close and restart the Internet Explorer browser for the changes you made to take effect. b> Mozilla Firefox b> Double-click the "Mozilla Firefox" icon to open the program. Type "about:config" into the address bar and press the "Enter" key. Type "dom.max_script_run_time" into the Filter text box and press the "Enter" key. Double-click "dom.max_script_run_time" to display the Enter Integer Value dialog box. Enter a value of "10" or "15" into the text box and click the "OK" button to save the change. Close and then restart the Firefox browser for the change to take effect. b> Safari b> Click the "Safari" icon to open the Web browser. Select the option for "Preferences" from the menu bar. Go to the Advanced tab and click the option for "Show Develop menu in menu bar." Click the option for "Develop" from the menu bar. Click the option for "Disable Runaway JavaScript Timer." Close and re-open the browser for the change to take effect.
b>
b>
1helpful
I keep getting a box on my screen every time i try to do anything. it says EvalInsandbox:SyntaxError:syntaxerror
Correct a Syntax Error Syntax errors are the most common problem for developers. A single syntax error can cripple even the best applications and websites. You can correct syntax errors easily once you find them. Typical errors include missing commas, semicolons and parenthesis. Debuggers are available in many software development kits to aid you in the location of syntax errors. However, you can find and correct syntax errors manually as well. Learning how to correct syntax errors is an essential part of being a software developer.
Double-click the "Internet Explorer" icon to open the program. Click the "Tools" drop-down menu and select "Internet Options." This will display the Internet Options window. Go to the "Advanced" tab and scroll down to the "Browsing" section. Remove the check from the box for "Disable script debugging (Internet Explorer)," "Disable script debugging (Other)" and "Display a notification about every script error." Click the "Apply" button to save the changes. Click the "OK" button to close the Internet Options window. Close and restart the Internet Explorer browser for the changes you made to take effect. b> Mozilla Firefox b> Double-click the "Mozilla Firefox" icon to open the program. Type "about:config" into the address bar and press the "Enter" key. Type "dom.max_script_run_time" into the Filter text box and press the "Enter" key. Double-click "dom.max_script_run_time" to display the Enter Integer Value dialog box. Enter a value of "10" or "15" into the text box and click the "OK" button to save the change. Close and then restart the Firefox browser for the change to take effect. b> Safari b> Click the "Safari" icon to open the Web browser. Select the option for "Preferences" from the menu bar. Go to the Advanced tab and click the option for "Show Develop menu in menu bar." Click the option for "Develop" from the menu bar. Click the option for "Disable Runaway JavaScript Timer." Close and re-open the browser for the change to take effect. Hope this helps.
b>
b>
Syntax 07 Error
Syntax 07 error may occur from the next reasons:
1. If the command contains a syntax error. Look for misplaced functions, arguments, parentheses, or commas.
2. Exponents can not be more than three digits.
3. Sign = is not valid in parentheses excepr where an expressions is required.
4. Axes in DifEq must be Q, t, or Q'
Return code 4
nder X0, if dial tone detection is enforced or selected, this result code is used to indicate that dial tone has not been detected. 3.12.5. ERROR (4)Modem returns this result code if the command line contains a syntax error or it is unable to execute a command contained in the command line
2helpful
What is ERR:SYNTAX on ti-84 plus calculator
If you want to correct the error you will have to disclose what you were trying to calculate.
Anyway, each command has to be written in a specific way ( a specific sequence of symbols) to be understood by the calculator.
Foe example, if the command is sin(X) you cannot write it as sin() X or X sin. You must respect the way a command is to be entered, otherwise you get rubbish or a SYNTAX ERROR message.
Usually the calculator will ask you GO TO or QUIT. If you choose GO TO the cursor will jump to the place where the error occurred and you may be able to correct the syntax.
2answers
How to install package manager in ubuntu?
A package manager is a program that installs and uninstalls software, and keeps track of all the components each piece of software needs.
Dpkg is the Ubuntu package manager dpkg is a medium-level tool to install, build, remove and manage Ubuntu packages. The primary and more user-friendly front-end for dpkg is dselect.dpkg itself is controlled entirely via command line parameters,which consist of exactly one action and zero or more options. The action-parameter tells dpkg what to do and options control the behavior of the action in some way.
Now we will see all the available commands for dpkg with examples
1) Install a package
Syntax
dpkg -i <.deb file name>
Example
dpkg -i avg71flm_r28-1_i386.deb
2) Install all packages recursively from a directory
Syntax
dpkg -R
Example
dpkg -R /usr/local/src
3) Unpack the package, but don’t configure it.
Syntax
dpkg --unpack package_file
If you use -R option is specified, package_file must refer to a directory instead.
Example
dpkg --unpack avg71flm_r28-1_i386.deb
4) Reconfigure an unpacked package
Syntax
dpkg --configure package
If -a is given instead of package, all unpacked but uncon-figured packages are configured.
Example
dpkg --configure avg71flm_r28-1_i386.deb
5) Remove an installed package except configuration files
Syntax
dpkg -r
Example
dpkg -r avg71flm_r28-1_i386.deb
6) Remove an installed package including configuration files
Syntax
dpkg -P
If you use -a is given instead of a package name, then all packages unpacked, but marked to be removed or purged in file /var/lib/dpkg/status, are removed or purged, respectively.
Example
dpkg -P avg71flm
7) Replace available packages info
Syntax
dpkg --update-avail <Packages-file>
With this option old information is replaced with the information in the Packages-file.
icon_cool.gif Merge with info from file
Syntax
dpkg --merge-avail <Packages-file>
With this option old informa-tion is combined with information from Packages-file.
The Packages-file distributed with Debian is simply named Packages.dpkg keeps its record of available packages in /var/lib/dpkg/available.
9) Update dpkg and dselect’s idea of which packages are available with information from the package pack-age_file.
Syntax
dpkg -A package_file
10) Forget about uninstalled unavailable packages.
Syntax
dpkg --forget-old-unavail
11) Erase the existing information about what packages are available.
Syntax
dpkg --clear-avail
12) Searches for packages that have been installed only partially on your system.
Syntax
dpkg -C
13) Compare Package versions version numbers
Syntax
dpkg --compare-versions ver1 op ver2
14) Display a brief help message.
Syntax
dpkg --help
15) Display dpkg licence.
Syntax
dpkg --licence (or) dpkg --license
16) Display dpkg version information.
Syntax
dpkg --version
17) Build a deb package.
Syntax
dpkg -b directory [filename]
18) List contents of a deb package.
Syntax
dpkg -c filename
19) Show information about a package.
Syntax
dpkg -I filename [control-file]
20) List packages matching given pattern.
Syntax
dpkg -l package-name-pattern
Example
dpkg -l vim
21) List all installed packages, along with package version and short description
Syntax
dpkg -l
22) Report status of specified package.
Syntax
dpkg -s package-name
Example
dpkg -s ssh
23) List files installed to your system from package.
Syntax
dpkg -L package-Name
Example
dpkg -L nagios2
24) Search for a filename from installed packages.
Syntax
dpkg -S filename-search-pattern
Example
dpkg -S /sbin/ifconfig
25) Display details about package
Syntax
dpkg -p package-name
Example
dpkg -p nagios2
Please check if this is any help for you.
Regards.
Can you correct my error message? command line option SYNTAX ERROR I get this message when I try to open a pps file. I have Microsoft Power Point installed on the computer. Thea.
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
