20 Most Recent Mozilla Firefox Questions & Answers
The Roblox is somehow a web based game but has an independent launcher however every time you hit the launcher in the desktop your will be directed into Roblox game server page, therefore, unblocking Roblox would be possible by simply blocking the URL address "www.roblox.com" of Roblox via URL filter feature in your router.
Mozilla Firefox | Answered on Sep 05, 2019
Download "ccleaner", uninstall firefox using ccleaner, scan/fix registries, then do a clean install of firefox using the following link
Download Firefox Free Web Browser
Mozilla Firefox | Answered on Mar 05, 2019
It sounds like firefox is not supported, so you will need to use Internet Explorer for this task. Be sure the program is updated, as IE also handles security functions....
Mozilla Firefox | Answered on Feb 26, 2019
Try doing a search engine search for google maps first.
http://maps.google.com should be the address to google maps, but sometimes it doesn't get put in quiet right.
Mozilla Firefox | Answered on Jan 12, 2019
Firefox crashes can be caused by incompatible extensions or themes, issues with hardware acceleration and the drivers on your system, problems with your Firefox settings and other issues. If Mozilla Firefox is crashing every time you reopen it, you can troubleshoot Firefox with its safe mode, update the software on your system or create a new Firefox profile.
Safe Mode b> Mozilla Firefox includes a safe mode startup option. Firefox doesn't use extensions, themes, hardware acceleration or your custom settings when you start in safe mode. You can start Firefox in safe mode by pressing and holding the "Shift" key while clicking the "Firefox" shortcut. Click "Continue in Safe Mode" when the dialogue box appears. If Firefox doesn't crash when you start in safe mode, the problem is with your Firefox configuration. b> Reset Firefox b> If Firefox starts without crashing in safe mode, you can make some of the safe mode changes permanent. Close Firefox and restart it in safe mode again. Use the dialogue box that appears to select one of the options such as "Disable All Add-ons" or "Reset All User Preferences to Firefox Defaults" and click "Make Changes and Restart" to restart Firefox in normal mode with the changes. After restarting, you can re-enable extensions and themes one by one and install updated extensions that may fix the problem. Update b> If Firefox crashes safe mode, updating Firefox and other software on the system may fix the problem. You can download and install a new version of Firefox from Mozilla.com if it won't start. You should also update Windows from Windows Update, update any browser plug-ins such as Adobe Flash and update for your antivirus, firewall and other security programs. The crash may be fixed with newer versions of the software. b> Profiles b> Firefox stores your settings in a profile directory. It normally creates only one profile directory, but you can create an additional profile and start Firefox with that profile instead of using safe mode. Close Firefox if it's open, click "Start," type "Firefox.exe -ProfileManager" into the search box in the Start menu and press "Enter" to access the profile manager window. Click "Create Profile" to create a new profile, provide a name for the new profile and click "Start Firefox." Firefox opens with a fresh profile; you can start your old profile from the profile manager window.
b>
Mozilla Firefox | Answered on Oct 23, 2018
install backer rod into cracks that are more than an 1/8 and use concrete sealer (in the caulking section of your local hardware store). The backer rod is used to reduce the amount of sealer you have to use to bridge the larger gaps in the cracks.
Mozilla Firefox | Answered on Sep 19, 2018
Save .json to desktop, drag browser window smaller from lower right edge till you can drag the .json into opened window., doubleclick titlebar to restore browser full size. In the tab that opens with .json data, click the bookmarklet. Another tab should open with links. You can save as .htm by right click "save page as" web page complete.
Mozilla Firefox | Answered on Jul 21, 2018
Hi. It is better to uninstall first your firefox version 4 then after that go to your drive C then go to program files then delete the folder mozilla firefox. Then install your firefox version 3.6.
Mozilla Firefox | Answered on Jun 29, 2018
If you have not updated to the newest version of FF, try doing that first. It sounds like you are having issues with browser plugins. You may have to un-install and re-install certain plugins if you already have the most updated version of FF.
Depending on what you have or do not have installed will depend on a proper course of action to fix the issue. Click on this link to see more detailed information on your particular problem.
I hope this helps and good luck!
Mozilla Firefox | Answered on May 16, 2018
To download firefox, please clikc the link HERE and go to browsers section.
Mozilla Firefox | Answered on Feb 04, 2018
In the Firefox location bar, enter the following location:
chrome://pippki/content/resetpassword.xul
and press Enter key. The Reset Master Password page will appear. Click the Reset button, to reset your master password.
Remember: Resetting your master password will remove all of your saved usernames and passwords.
Mozilla Firefox | Answered on Dec 22, 2017
According to http://www.mozilla.org/projects/securit ... slerr.html it is
SEC_ERROR_OCSP_INVALID_SIGNING_CERT -8048 "Invalid OCSP signing certificate in OCSP response."
In Firefox go to Tools -> Options -> Advanced -> Encryption -> Verification
[v] Do not use OCSP for certification validation
As this normally checked by default.
From http://kb.mozillazine.org/OCSP_error_wh ... cure_sites
Mozilla Firefox | Answered on Oct 15, 2017
Make sure you have pop ups blocked
Open Firefox
> Open Menu (stack of books icon, top right)
>Options
>Content
> Check the box to stop pop-ups
> OK
Download and install the free ABP plus software
Adblock Plus
Mozilla Firefox | Answered on Jun 13, 2017
Mozilla is still under development and isn't going to support everything ie does because ie has been around since the stone ages an people have better programming skills for ie
Mozilla Firefox | Answered on Apr 25, 2017
If someone has blocked you from accessing the domain roblox.com you can try a couple things. Try accessing the secure version of the site:
https://www.roblox.com/Landing/Animated
If that doesn't work, try using a proxy service. This will work unless your administrator has blocked access to the proxy service:
https://proxy.org/
Mozilla Firefox | Answered on Dec 06, 2016
1,636 questions posted
Top Mozilla Computers & Internet Experts
Alli Abiola
Alli Abiola
Peter Dragonetti
Are you a Mozilla Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Mozilla Computers & Internet
Most Popular Question
when enter address google maps not open
  • Computers & Internet
