20 Most Recent Microsoft Windows XP Professional Edition With Service Pack 2 for PC Questions & Answers
When i open kundli 2009 it gives me file not found satnam.jpg error 53
This error in kundli 2009 is because of missing hidxp.dll Below are the links to fix this error hidxp dll error fix How can fix hidxp dll error effectively or What HIDXP DLL Best How to Fix HIDXP DLL Error Guide Thank You!
1/25/2016 10:43:12 PM • Microsoft... • Answered on Jan 25, 2016
Windows xp service pack 3 serial key
D3JMD-XDV9V-DCKBQ-PKF4C-X3TJT
8/26/2015 3:07:32 AM • Microsoft... • Answered on Aug 26, 2015
Repair win xp pack3
You need to use Windows XP Professional SP3 media dvd if you want to use your XP Pro SP3 product key. As far as I know, the SP3 product key does not work with the previous version of media (non-SP, SP1, and SP2).
5/7/2014 7:18:39 PM • Microsoft... • Answered on May 07, 2014
Xp pro prod key for cd kit 394378-002
If you have a desktop computer, look for the "genuine" Microsoft decal on the side/back of the case.
If you have a laptop computer, look for the "genuine" Microsoft decal on the bottom of the case.
You'll find a 25-character license-key. Enter that key, when prompted, during the installation of Windows XP.
3/31/2014 9:00:15 PM • Microsoft... • Answered on Mar 31, 2014
I CAN'T RUN / START TRIAPC.EXE
Test your software and fix it using Norton Utilities (download and run it): http://download.cnet.com/Norton-Utilities/3000-18512_4-10907620.html
3/4/2014 2:13:35 PM • Microsoft... • Answered on Mar 04, 2014
0answers
3 serial key
Be the first to answer 12/31/2013 6:43:54 AM • Microsoft... • Posted on Dec 31, 2013Be the first to answer
I have a virtual machine running xp sp2 but the applications i want to put in it need sp3 can i get it as a update or something or do i need to remove the virtual machine and make a new one with sp3?
The link below will take you to Microsoft's website which will allow you to download service pack 3. Remind you that this is the full install for service pack 3 and will require service pack 2 already installed. http://www.microsoft.com/en-us/download/details.aspx?id=24
12/17/2012 11:03:56 AM • Microsoft... • Answered on Dec 17, 2012
Newheur_pe virus
Start your PC and press F8 several times until the boot menu comes up. Then select "Safe Mode with Networking". Now get some or ALL of the FREE programs below.Download, Install and Run Malwarebytes Anti-Malware:http://majorgeeks.com/download.php?det=5756When Installing choose the non-pro version.Download, Unzip, Install and Run TDSSKiller:http://majorgeeks.com/Kaspersky_TDSSKiller_d6895.htmlDownload, Install and Run Super Anti-Spyware:http://majorgeeks.com/SUPERAntiSpyware_d5116.htmlIf you have an outdated Anti-virus program then Download, Install and Run Avira Anti-Virus:http://majorgeeks.com/Avira_AntiVir_Personal_-_FREE_Antivirus_d955.htmlMake sure to select ALL of the "threat categories" when you install or configure Avira...You should be in pretty good shape if you run and install all of these programs.
8/17/2012 5:29:29 AM • Microsoft... • Answered on Aug 17, 2012
Computer says it is in save mode
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your computer and operating system Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart hope this helps
6/22/2012 10:12:56 PM • Microsoft... • Answered on Jun 22, 2012
My sounds are not in sync with videos or games after installing ie8 - can it be fixed?
Upgrade to Service Pack 3, ie8 will work better and should solve the lag time between audio and video.
6/18/2012 9:53:15 AM • Microsoft... • Answered on Jun 18, 2012
Every time i open my pc its always hang on windows
try to open your windows in safe mode. (when you turn on your PC press F8 repeatedly), then choose safe mode. Once you entered on safe mode, go to start, RUN then MSCONFIG. then go to STARTUP. Uncheck all items then OK restart.
5/10/2012 6:35:56 AM • Microsoft... • Answered on May 10, 2012
Cd kit 394378-002 give product key
QW4HD-DQCRG-HM64M-6GJRK-8K83T THIS PRODUCT KEY WILL HELP YOU
8/29/2011 10:54:12 AM • Microsoft... • Answered on Aug 29, 2011
How to merge tow drives in windows XP , the c
There are a couple of solutions to this problem but most of them require technical use of drive partition tools like Bart Pe or partician magic or some linux tools can move NTF files around as well.
.The simplest way is to back up your data and reinstall windows making sure that you delete and reformat all partitions when doing the install.
I hope this helps
Andrew
3/26/2011 11:25:19 AM • Microsoft... • Answered on Mar 26, 2011
3answers
I have a laptop running XP Professional. I
Welcome to Fixya. The problem with the connection is that you need to check if the Windows XP SP2 settings is the same with the router.
First you need to access the router settings page and check if the security is the same of the computer. Access the router type 192.168.1.1 then type admin for username and password for password. Select Wireless Settings. I need to verify if the Dot is on WPA2-PSK (AES).
If the settings is the same as above then we will configure the settings on your Windows XP Laptop.
- Go to Control Panel, Network Connection, Right Click on Wireless Network Connections then select Properties.
- Click on the Wireless Networks Tab on the Wireless Network Connection Properties window.
- Hightlight the SSID or Your Network Name and the click on the Properties Button.
- If your using WPA2 then change the dropdown to WPA2-PSK if the option is available.
- Data Encryption is AES same with the router, then retype the Network Key that you save on the router
- Then click Ok to close the window. Try to browse and hopefully this fix the issue.
If you have questions please let me know. Thanks for using Fixya.
3/6/2011 8:56:48 PM • Microsoft... • Answered on Mar 06, 2011
2answers
I want a product for XP service pack 3.. can any
Try this here: KYKVX-86GQG-2MDY9-F6J9M-K42BQ
7/15/2010 9:59:38 PM • Microsoft... • Answered on Jul 15, 2010
Applications Closing Instantly
Yes, it sounds like a computer-virus.
Remove the disk-drive from your desktop computer,
and attach it as a "slave" disk-drive to some other desktop computer, and then run a full virus-scan.
Or, just follow "best practises":
* backup your data & music & E-mail & contacts,
* reinstall Windows from trusted media,
* run Windows Update a bunch of times,
* reinstall anti-virus software,
e.g., http://www.microsoft.com/security_essentials
* reload your files.
4/18/2010 12:40:31 AM • Microsoft... • Answered on Apr 18, 2010
I need to complete download for win xp ser pk 2
i need to download hp laserjet 1010 driver for windows xp
12/28/2009 6:55:53 AM • Microsoft... • Answered on Dec 28, 2009
2answers
I need product key for my cd kit 394378-002
there is no product key for these discs, they are system restore discs and you have to use your windows licence key that is on a sticker on the pc. if you do not have a licence key sticker you will have to purchase one from Microsoft.
11/27/2009 1:33:14 PM • Microsoft... • Answered on Nov 27, 2009
Microsoft Windows XP Professional Edition With Service Pack 2 for PC Logo
Popular Tags
32 questions posted
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
XP Microsoft
  • XP Microsoft
Most Popular Question
windows xp service pack 3 serial key
  • Computers & Internet
