20 Most Recent Texas Instruments TI-83 Plus Calculator Questions & Answers
My house roof has an
the area of your roof is equal to the base (B) times the hight (H) divided by 2.
A = ( B x H )/ 2 = 120
To get the Perimeter of your roof you need to sum the base plus the sides (S)
So P = B + 2 x S
if you have a slope degree of 30 then
B/2 = cos (30) x S
so P = B + 2 x B / 2 / cos(30)
P = B ( 1 + cos (30) )
we also know that
H = tg (30) x B/2
from this last one we can go back to the Area and get a value for B
120 = ( tg (30) x B / 2 x B) / 2
480 x SQRT(3) = B^2
B = SQRT(480/tg(30))
So:
P = SQRT(480/tg(30)) x ( 1 + cos (30))
tg (30) = 1 / SQRT(3) cos (30) = SQRT(3)/2
P = 2 SQRT(30 x (12 + 7 x SQRT(3) ) ) or aproximately 53.8m
3/18/2024 12:06:21 PM • Texas... • Answered on Mar 18, 2024
4answers
Screen Gibberish
Wow, I'm in the exact same situation. I've had my trusty TI for 6 years and now all of a sudden this gibberish is on the screen. You're right, there is absolutely nothing you can do to fix it. Guess we'll have to bite the bullet and buy a new one.
12/3/2023 1:16:55 PM • Texas... • Answered on Dec 03, 2023
2answers
I'm doing radicals I need to type an exponent into
Use the xth-root function to compute any root. It's the fifth entry on the MATH menu, which you can get by pressing the MATH key. The fourth entry on the same menu gives you the third root without needing the 3 to be specified.
For example, to compute the 5th root of 32, press 5 MATH 5 3 2 ENTER.
8/10/2022 8:35:56 AM • Texas... • Answered on Aug 10, 2022
16answers
Need help withe the sin, cos, tan problem with ti - 83 plus
here are the steps in changing it from radian to degrees
1. turn on your TI-83 plus
2. press the MODE button near the top of your calculator
3.go down to options and move the highlight from radian to degree, press enter and clear
you're good to go
5/14/2022 3:54:33 AM • Texas... • Answered on May 14, 2022
TI-83 Plus ( finding linear regression) gives wrong y-intercept (b=) value sometimes. Please tell me why?
I get the same answer. Is b wrong? When I do it in Excel I get b= -2E+06, which is -1 797 322.99 rounded to the millions, in scientific notation. Let me know if you have any questions. Good luck, Paul
10/21/2021 3:29:23 AM • Texas... • Answered on Oct 21, 2021
My 1-var stats button is not working it says the
You will have to report faithfully the message returned, you cannot use your interpretation of the message. Error messages are codified. Each one will correspond to very particular error conditions. I did check the manual for all possible error messages and there is none that states wrong info.
My hunch is that there are errors in your data, but I can't say what type of error: I do not have the actual message returned. Verify you data, item by item, and try again.
To make sure that the calculator is well configured to do statistics
  1. Press [STAT][5:SetUpEditor][ENTER]
  2. Press [2nd][0] (CATALOG) and press [PRGM] (C) to jump to the first command starting with C.
  3. Scroll down to [ClrAllListsts] and press [ENTER]
  4. Calculator replies Done
Restart your statistical data entry.
Hope it helps.
Thank you for rating this solution
3/7/2021 11:24:07 PM • Texas... • Answered on Mar 07, 2021
3answers
Mem cleared
Press any key (except for 2nd and On), and the message should disappear.
3/12/2019 10:36:31 PM • Texas... • Answered on Mar 12, 2019
2answers
How do you calculate the cubed root of a number or
For cube roots, use the cube-root function in the MATH menu. For example, to calculate the cube root of 8, press MATH 4 8 =
For other roots (including cube root), use the xth-root function in the MATH menu. For example, to calculate the fifth root of 32, press 5 MATH 4 3 2 =
8/3/2018 9:54:18 AM • Texas... • Answered on Aug 03, 2018
Gives wrong answer for power function
You should learn about scientific notation. The two values are the same, just written differently.
5/20/2018 11:48:14 PM • Texas... • Answered on May 20, 2018
0answers
Buttons don't work...
Be the first to answer 1/18/2018 11:42:03 AM • Texas... • Posted on Jan 18, 2018Be the first to answer
7 button doesn't work
If you're talking about your laptop, try to gently remove the button and clean it with a laptop cleaner. spray a bit of it on a small piece of cotton until its damp, not wet, and clean the area, and put the button back on. If it is infact something wrong with the sensor take it to a local computer store. If you're working with a mac, apple should have a solution for you.
1/6/2018 1:12:54 PM • Texas... • Answered on Jan 06, 2018
0answers
TI83+, display issues
Be the first to answer 12/27/2017 11:15:02 PM • Texas... • Posted on Dec 27, 2017Be the first to answer
0answers
My calculator won't let me graph or find the linear regression.
You have attempted to use, edit, or delete an archived variable. For example, the expression dim(L1) produces an error if L1 is archived
11/11/2017 10:24:02 AM • Texas... • Answered on Nov 11, 2017
Texas Instruments TI-83 Plus Calculator Logo
2,095 questions posted
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Texas Instruments Office Equipment & Supplies
Most Popular Question
house roof
  • Office Equipment & Supplies
