1 tera
SOURCE: wd my book device usb device not recognized by computer
Hi, Take the drive to a pc store and ask the techs to move the HDD into a new shell and test it for you. Most likely it's ok and you can just buy a new shell/enclosure for it. If that doesn't work it may need the help of a recovery pro. If that's the case comment back here with your country/state/city and I'll pass on a recommendation for a nearby facility that can assist you in retrieving the files. Chris
SOURCE: wd 320 external hdd acting up
WD has had issue with eir enclosures if you fixed the partition there is the possibilityt that you lost information in the process.
On thisng that you can do is remove the drive from the current WD enclosure and buy an new one. Then try to see if youa re able to locate any of your files. Also check to see if it reports any available space if it still does not then the actual hard drive hase the issue and you will need to buy a new one.
SOURCE: sandisk 4gb won't open, shows 0 bytes free and 0
came a cross similar problems with San disk this product is not worth a penny
even non branded flash pens works better then this piece of ****
sorry guys but this is the facts tried my level best useing all the tools possible even their own tool couldn't detect the disk its 4gb showing 64 MB only
SOURCE: 4 GB pen drive show property as 0 byte used and 0
4 GB pen drive show property as 0 byte used and 0 byte free..when subjected to open show insert disk please help!
