20 Most Recent
Kingston flash memory card - 256 MB - MMCplus Graphic Card Questions & Answers
My kingston 8 gb data traveller suddenly became
try maybe it is bricked or damaged, try downloading Pheonix products which can help u repair any usb damaged storage media, worked on my 8gig usb and nokia n95, or u can try googling flashing utilities for you flash
Hai dear frndzzz
hi,
What should we do if we forget the password? For S60 1st and some of
2nd phones, such as Nokia 3650, Nokia 6600 and Nokia N-Gage, the
password is stored in a plain text file.
- Firstly, you need to install FExplorer, a free file manager that allows us to browser through S60 file system.
- Next, launch FExplorer and then browser to c:\system folder. There is a file, called mmcstore.
- Rename the file to mmcstore.txt and then open it. Your password must be several characters at the end of the file.
For S60 3rd Phones, Nokia N-Series and Nokia E-Series
Unfortunately, there is no way to recover the password in the latest S60 phones. The only way that I know so far is by
reformatting the memory card.
It can be done from Memory Card application by selecting Options |
Format memory card menu. Of course, you will lose all your data in the
memory card…
Thank you
Cant see mmc
go on sandisk website and made show your mmc from there
Its possible to convert a
No it is not possible at present.
I think what they are refering to is it's ability to store graphics, like video and pictures.
Take care!
damnor01
I have use my pen
you mean you want to use your pendrive as graphic card. its as confusing as a fat kid with salad on the table. however, you can ure your flash drive as a cache divice via eboostr.
I cannot romat my flash
Check for a small switch on the side and turn it off. You will then be able to write to the drive.
Kingston usb asks again and again format
Insert the drive, go to "My Computer", locate the drive in the list, right click it, select "Format" and follow the instructions. Most flash drives are FAT32 but you can format them NTFS
Unlockin mmc
use in comand prompt
format Z:\ /X /FS:FAT
replace Z with ur mem card drive letter
My pen drive is only reading data in one computer,
This is most likely due to a damaged or dirty female connector on the "data error"'ing computer. Try blowing some compressed air in the slot, or looking inside to see if there is some lint inside; it happened to me with a SD card once.
Try loading the pen drive onto a third computer to exclude the (very unlikely) possibility that the flash drive is borderline faulty (e.g., requires a slightly higher voltage than normal to be read).
Kingston
sir if you are using adaptor of memory card for connect it with pc then i think this error occurs so use card reader and then insert the memory card in it..........the right click on the removal disk and click format
when you click on format then click quick format then o.k
if this error occurs again then scan the device or go to device manager and then check whether the property of usb is enable or disable
if error still continue then mail me at
[email protected]
i will help you again
take care
