20 Most Recent
Cisco ASA 5520 Firewall Questions & Answers
I desire to block video
You can not do content filtering with ASA firewalls with IOS. You will need to buy a content filtering solution, or sign up for a inexpensive content filtering with OpenDNS.org. This is a good content filtering basic system with white and black listing capability.
I have some problems with
What version of software are you running? I have noticed issue with ssh on version 8.2(3) and below.
You can try to remove all ssh access and then add it back.
Also you can try zeroizing and regenerating the crypto key.
What command do i run to show IpSec tunnel status
show ipsec stats
this command was introduced in code 7.0
it will show the active tunnels, the previous tunnels and several other stats of inbound and outbound packets.....
for example:-
IPsec Global Statistics
Active tunnels: 2
Previous tunnels: 9
Inbound
Bytes: 4933013
Decompressed bytes: 4933013
Packets: 80348
Dropped packets: 0
Replay failures: 0
Authentications: 80348
Authentication failures: 0
Decryptions: 80348
Decryption failures: 0
Decapsulated fragments needing reassembly: 0
Outbound
Bytes: 4441740
Uncompressed bytes: 4441740
Packets: 74029
Dropped packets: 0
Authentications: 74029
Encryptions: 74029
Encryption failures: 0
Fragmentation successes: 3
Pre-fragmentation successes:2
Post-fragmentation successes: 1
Fragmentation failures: 2
Pre-fragmentation failures:1
Post-fragmentation failures: 1
Fragments created: 10
PMTUs sent: 1
PMTUs recvd: 2
Protocol failures: 0
Missing SA failures: 0
System capacity failures: 0
How to block a port
hi,
when u login in ASDM you can find on right side services and u create one whre u add which all ports u want to and apply that in ur rules
Need some basic show command to troubleshoot
mode exec user Router)
ping ip
show ip route
show version
traceroute ip
mode exec priveligiado
show arp
show interface
show protcols
show ip protocols
show startup-config
erase startup-config
reload
How do I recover firewall password?
You may refer to the steps in the link below:
http://www.cisco.com/en/US/docs/security/asa/asa72/configuration/guide/trouble.html#wp1049302
I hope this helps!
Problem in installing the asdm image ASA 5520 ver 7.1
I had this same issue on my ASA 5520.
1. Copy the config and IOS image to a tftp server.
2. Format flash (disk0)
3. set rommon server, ip addy, and file settings.
4. tftpdnld
5. Once the system has booted to the image copy the asa image file, asdm image file, and config to flash
6. configure asdm image default location and reload
Hello all
If you are going for factory reset use the following commands
asa>enable
asa#write erase
asa#reload
Dont save the configuration when it prompts for it.
if you want to restore the configuration from the backup
1. You need to have a TFTP server
2. Locate the config file on your TFTP server
3. TFTP server should be reachable from ASA
then
asa#copy tftp flash
give the tftp server ip address
give the configuration file name (as exactly on the TFTP server)
reload
