When you install a larger SD card it will be a fresh empty memory card. Your existing 8Gb SD card will still have the the 5 hour gig data on it. You can insert the 8Gb SD memory card into an USB memory card reader and plug this into the USB port on your computer. The computer will see this SD memory card and adapter as an external storage device. You can then open the audio folder on theis SD memory card and copy this file to your computer.
you can recover pictures from sd card with SD Card Recovery Software like asoftech photo recovery, the card recovery software not only recover photos, but also videos, music files and other files. download the software from SD Card Recovery Software
you need to either purchase a micro sd card adapter or a usb memory card reader, they are both pretty cheap and available in most supermarkets/electrical outlets but cheaper still on ebay/amazon/play etc it all depends how fast you need it.
If the 8Gb SD card works on your HD camera, then the problem is with your built in memory card of your computer. Most of the built in memory cards of the computer only supports up to 2Gb. You can actually isolate it by trying to test an SD card lower than 8Gb to your computer. Solution for this is to use external USB SD reader that supports high capacity SD card (SDHC) or contact the manufacturer of your computer and ask for firmware updates for the memory card reader. Hope this is clear and would help you.
Storage Media is just an USB stick or any type of memory stick (xd card, sd card, cf card, even micro sd is considered 'storage media') If you are trying to update and it is asking you to insert the firware with the storage media, you will have to put the files on a usb stick or any type of storage media and then insert the card in either the memory card slots (if you have a original 60/80g launch model), or use a memory card reader.
I hope you understand. Please post a new question if you need further assistance or click chat on my page.
Hi, look here's what to do, get yourself, or access to, A Computer, and a USB SD card reader, now, insert your 8GB SD card into the reader/writer, It will show up as a HDD in My Computer, and then, Format it FAT32. Now return it to the Camcorder, when turned on again, the Camera NOW should "See" the SD card. You may even be asked if you wish to Format,again,say YES, and do so, if NOT asked that;s OK too. as, you should now be able to, in either case, be able to have access to the SD card, and can change your phone settings accordingly, the extra storage will simply be "Picked Up" by the Camcorders software.
If this doesn't happen, then there maybe a problem with THAT SD card or the Camcorder? try another SD card before thinking the camcorder has a problem though.
Same thing happened to me, after taking some pictures of a christening, connected to card reader, it wasn't recognised by card reader. I re-inserted it in camera and got card error, tried some softwares to extract pics but for nothing!!! I'm very dissatasfied!!
I insert my
Red bridge multi in one memory card reader and a 2gb M2 card(with data) in the right slot yet I receive a please insert disc?? when I click the removeable (H)of Red bridge(which is detected by my pc)
Hi!
This is a feature and not a defect of the CX-12 that reminds the user that the memory stick inserted might not be able to record the data from the camera effectively. HD video requires a memory stick with a relatively fast data read/write speed, and the CX-12 recommends not using any other stick that is not Mark 2.
Fortunately, though, as you have found out, it does not affect the camera's ability to record in non-Mark 2 sticks.
Hope this helps!
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
Open up 'My Computer'. You should see it under the list of available drives.
Check its contents first to make sure that you have the right drive.
In 'My Computer', right-click on the drive and choose 'Format'.
5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
Did you load the software for the card reader?
