20 Most Recent Sony 4GB Memory Stick PRO Duo Memory Card Questions & Answers
I also have problem where all my photos were
Search online for "memory stick file recovery" programs.
Like reading through a book, page-by-page, because the Table-of-Contents is illegible, these type of programs will read through every file on the memory-stick, trying to "stitch" the pages back together.
10/6/2014 10:30:56 AM • Sony 4GB Memory... • Answered on Oct 06, 2014
Why can't I access my photos on my computer from sony memory stick pro duo 4GB but can view on camera?
You may be able to get the images from the card. try using a program called BadCopy Pro. I used it a few times to get back images from memory cards that would not work on any computer. Good Luck.
8/17/2014 4:14:26 AM • Sony 4GB Memory... • Answered on Aug 17, 2014
How to format a psp card ig saying please insert disk
If you have formatting software, you will need to use it and format the disk to fat32 file system (not ntfs).
6/22/2014 8:28:33 AM • Sony 4GB Memory... • Answered on Jun 22, 2014
Memory card said please insert disk
CHECK IT IF IT IS PROPERLY INSERTED, OR IT MAY BE PASSWORD PROTECTED, TYPE UR PASSWORD, OR FORMAT IT , IF U FORGOT PASSWORD, BY BACKING UP THE DATA AT PC, COZ WHOLE DATA WILL BE LOST AFTER FORMATTING http://www.tinyurl.com/9307740
5/15/2014 7:24:56 AM • Sony 4GB Memory... • Answered on May 15, 2014
3answers
How can i recover the pictures in my SD pro duo
you can recover pictures from sd card with SD Card Recovery Software like asoftech photo recovery, the card recovery software not only recover photos, but also videos, music files and other files. download the software fromSD Card Recovery Softwarehope this helps.
4/7/2014 7:11:12 AM • Sony 4GB Memory... • Answered on Apr 07, 2014
How can I copy/transfer pictures from memory card to laptop?
use USB data card with device / card reader and browse you corresponding file to be copied / moved please be careful when you use memory card in card reader chek whtr its properly fixed
1/27/2014 1:10:56 AM • Sony 4GB Memory... • Answered on Jan 27, 2014
4 gb jumptwist
at the command prompt type chkdsk X: /f /r where X is pen drive.If it doesn't work download the recovery tool here http://freeware-fix.blogspot.com/2013/04/usb-drive-is-unreadable.html
12/24/2013 1:08:53 PM • Sony 4GB Memory... • Answered on Dec 24, 2013
I cant open m y memoty card pictures and videos in
Try to repair with rmprepusb website - Tutorial 28
11/1/2013 9:43:11 AM • Sony 4GB Memory... • Answered on Nov 01, 2013
2answers
My sony memory stick pro
There should be a lock switch on the card, most likely on the left side. Slide the switch into the opposite position and see if this fixes the problem. If not, try formatting the card from your camera and then attempt to load it on to your computer.
9/3/2013 2:14:56 PM • Sony 4GB Memory... • Answered on Sep 03, 2013
0answers
3answers
My memory stick of 1gb
That means the memory card was corrupted. You need a memory card recovery to recover photos before seeing it. I recommend you use Card Data Recovery, i can recover data from corrupted or damaged memory card.
6/19/2013 5:47:01 AM • Sony 4GB Memory... • Answered on Jun 19, 2013
Error in memory card
wait for sometime.
3/26/2013 2:10:41 PM • Sony 4GB Memory... • Answered on Mar 26, 2013
How to protect pro duo card from unauthorised viewing
you enter card into computer and and going card properties,there having security system.
3/26/2013 1:37:49 PM • Sony 4GB Memory... • Answered on Mar 26, 2013
Computer doesn't recognise memory stick pro duo 4gb
Hello Guys,
The computer sometimes doesn't recognize the memory stick device due to corruption, there are numerous causes for memory stick corruption for example virus attack, improper removal, wrong usage of the memory stick device and many more. After such corruption scenario data are lost from these devices, but luckily you can recover memory stick files by using an efficient recovery application like Yodot Photo Recovery. Apart from memory stick the tool also recovers files from all other devices like memory stick, hard disk, iPods, music players etc. Try using this tool to recover your data from memory stick
3/11/2013 2:10:42 PM • Sony 4GB Memory... • Answered on Mar 11, 2013
Showing in mic.. cord shotcut
HOW TO INSTALL DCIM LINK IN MY 8GB SCAN DISCK MEMORY CARD PLS HELP TO ME
2/22/2013 4:32:37 PM • Sony 4GB Memory... • Answered on Feb 22, 2013
Pictures on memory card not showing up on camera (DSC-T70)
You most likely did not safely remove the card from your computer and corrupted the cards MFT. You will need to format the card in the computer. It should work after that.
2/3/2013 8:45:15 AM • Sony 4GB Memory... • Answered on Feb 03, 2013
Memory card not detected in laptop
A few important bits of information about using faults and fixes on usb drives w7 First, please disconnect all USB devices and then perform the following steps: Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary. In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK". Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers". Then, restart your computer and Windows 7 will reinstall all USB controllers automatically. Click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts Click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box (I have found better results ticking the first box then reurn and tick the second box) you should not do anything while the chkdsk utility is in progress any input may damage this drive also you might need to do this Click start click to open on my computer you should see your usb drive F: right click select properties there will be an array of options select the sharing tab option then advanced sharing permissions make sure you have a tick in the share this folder box then click permissions make sure all three boxes are ticked you full control change and read in windows 7 Click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP also If you are running a Windows XP OS then you might be able to: Click start right click on my computer select open Right click the icon of your Flash Drive (It should be F: / E: or something) Click Properties in the menu that comes up Click the Sharing tab Click permissions And finally, click Allow next to Full Control. Hope this helps.
1/11/2013 3:54:52 PM • Sony 4GB Memory... • Answered on Jan 11, 2013
Sony 4GB Memory Stick PRO Duo Memory Card Logo
Popular Tags
198 questions posted
Top Sony Electronics - Others Experts
Sean Wright
Sean Wright
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Electronics - Others
Most Popular Question
recover pictures in sd pro duo
  • Electronics - Others
