Amana 3.5 cu. ft. Front Load Washer Logo
i
itsmedani Posted on Feb 07, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Amana Front loader washer locks the door, fills with water then stops & 20mins later reads nd
We just moved into a new house & now my Amana front load washer will lock the door, fill with water & then 20mins later it reads "nd". I did the master reset & nothing, please help.
RonW
Level 2:
Scholar:
New Friend:
  • Expert 111 Answers
  • Posted on Feb 08, 2014
RonW
Expert
Level 2:
Scholar:
New Friend:
Answers
111
Questions
0
Helped
39850
Points
148
Need a full model # all #'s to possibly help
2 Related Answers
tbirdfan1
Michael Thomas
  • 3056 Answers
  • Posted on Nov 05, 2011
SOURCE: amana front load washer error code "nd". Door is
Hello there and welcome to fixya
From what you're describing it sounds like the drain pump is blocked. The nd error code indicates "no drain". If the unit can't drain it won't spin. You're going to have to slide the washer out far enough to remove the rear panel; be careful not to damage the floor. Once you get the rear panel off you will see the pump. Be sure to have plenty of towels & a small container to catch water. I am sending you instructions from the service manual to remove and replace the pump. Another possibility is the drain line is blocked or something is stuck in the tub to pump hose.
Anonymous
  • Posted on Nov 18, 2010
SOURCE: amana front load washer door locked with door open
To get the front off. (All screws look to be #2 Phillips Screws)
1. You have to unscrew (2) phillips screws from the back that holds the top on.
2. Slide the top off. (slide towards the back)
3. Then where the control panel is there is about 4-6 screws holding that plastic piece on, take those out this will allow you to pull the control panel up and out of the way.
4. At this point you can unscrew the 4-6 screws in the door area that holds the front of the washer on, once you unscrew those screws there is a tab that you have to lift the front over to pull the front off. This will allow you access to the locking mechanism.
5. There are only 2 screws holding te locking mechanism on.
1helpful
My front loader Amana 7300 washer won't fill, how do I get the water to start?
Make sure the hoses are connected to the correct taps & the right temperature is selected.
Check water inlet valve have all wires connected to them.
I have a amana front loader washer and it was doing its norman cycle and stopped at 35 min left and wont do anything and the door was locked so I unplugged it for a hour went back and pluged it in makeing...
This is an error involving the door switch, it is actually DS not D5. The door may not be closed properly, try pushing it in. Or you may need a replacement door switch.
"nd" code on my washer, after I moved residence what would cause that?
Nd = no drain. Either drain pump is clogged or defective. Too many suds can also cause this problem.
My front loader does not get no water in it
Hello - Washer not filling with water can be caused by many reasons. Most common cause is a faulty switch that doesn't allow the value inside turn or a kinked fill hose. Other possibilities can be water valve faults, faulty control board, pressure switch or wiring failure. Are the house valves turn on fully? Contact a professional to move forward accurately?
19helpful
3answers
Amana front load washer error code "nd". Door is
6helpful
2answers
Amana nfw7200 washer stopped in middle of cycle and is flashing ''nd''
is it full of water? if so there is a drain problem and may have to clean out the pump
I have a two-year old Frigidaire GLTF2940FSO front loader washer that has stopped in the middle of a load leaving water in the drum and will produce a buzzing sound no matter what cycle you put it on. We...
did you try unplugging it and plugging it back in to see if you can get it to reset? Would it buzz when you try to drain it? Does the door latch lock when it goes into the wash cycle? Usually the door latch locks when it goes into the wash cycle and stays locked. So it filled up, the door latch should lock, then should go into wash cycle. Then you said few minutes later it stops. How did you get the door open? reason i ask is Usually i would see the clothes get stuck inside the washer because the door latch is still locked when it stops. Was the door unlocked when it stoped. If so maybe something going on with the communication from the board to the door latch maybe. Did you try operatin the drain?
Top Amana Washing Machines Experts
Virgil Watts
ZJ Limited
ZJ Limited
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
