HP Pavilion dv4000 Notebook Logo
A
Anonymous Posted on Feb 07, 2014
Can you reset your computer back to factory setup
Computer will not boot up screen come up gray
Thomas white
Level 1:
New Friend:
  • Contributor 16 Answers
  • Posted on Jun 07, 2019
Thomas white
Contributor
Level 1:
New Friend:
Answers
16
Questions
Helped
127381
Points
31
Sound like you are having a start up problem. Try this method. When you start the computer keep pressing FFelon your keyboard until you see a screen pop up asking what you want to do. Use the up and down keys on the keyboard to check use last known good start up.
If this fails repeat this again and then click on run dinosticts. If it asks you later to use system restore check yes. If all failes you may need to redownload widows again if you don't have the widows installation disk. However if you do have the disk that came with the computer. Start with that and use it to restore your computer loading drivers for your computer. And load fix my computer. I hope that this helps you somehow.
Onkar Sehgal
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jun 06, 2019
Onkar Sehgal
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
352
Points
10
One of the main reason to reset the computer is a slow computer. You can follow this gude here to speed up your computer before you reset it. http://www.mytechfellow.com/why-my-computer-is-so-slow
JMEX
Level 2:
Scholar:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 75 Answers
  • Posted on Feb 18, 2018
JMEX
Expert
Level 2:
Scholar:
Cheetah:
Answers
75
Questions
0
Helped
11082
Points
136
1) connect to external monitor to see if it works. If it doesn't work, then its a video card on the motherboard issue.
2) If connect to external monitor works, then its the screen or screen connection on the laptop.
1helpful
How to factory reset a Emachines Etower 633id it boots up but says operating system not found it has Microsoft Windows ME Millennium Edititon (from Windows 2000 Professional)
  1. Boot the computer to the boot menu: To do this, restart the computer and press the appropriate key when prompted to enter the boot menu. On most eMachines computers, this is the "F12" key.
  2. Select the CD/DVD drive as the boot device: Use the arrow keys to select the CD/DVD drive and press the "Enter" key to boot from it.
  3. Insert the Windows ME boot disk: Insert the boot disk into the CD/DVD drive and restart the computer.
  4. Choose the "Start Computer with CD-ROM support" option: When prompted, choose the "Start Computer with CD-ROM support" option.
  5. Run the Windows ME setup program: The setup program should start automatically. Follow the on-screen instructions to install Windows ME.
  6. Format the hard drive: During the setup process, you will be prompted to format the hard drive. Choose the "Full" format option to erase all existing data and perform a complete factory reset.
  7. Install Windows ME: Continue to follow the on-screen instructions to complete the installation of Windows ME.
After the installation is complete, the computer should be in a factory reset state and you can begin setting it up as a new system.
Please note that resetting your computer to the factory settings will erase all personal data and installed programs, so be sure to back up any important data before proceeding with the reset.
1helpful
2answers
How to factory reset an E560 lenovo thinkpad
ck this out hope it helps.
https://www.youtube.com/watch?v=j7G93cWDVqo
Factory reset toshiba A105-S4384
Put Recovery Disk 1 in the CD/DVD drive, then power off your computer, unplug everything from the unit including the AC, remove the battery, press and hold down the power button for 30 seconds, replace the battery and then AC, power on, at the Toshiba logo screen press 'F2' to enter the BIOS Setup, in setup press 'F9' to load setup defaults, press 'F10' to save and exit, now at the Toshiba logo screen press 'F12' to enter 'Boot Sequence', with the up and down arrow keys to select 'Optical Disk Drive' or 'DVD/CD Drive', you will then see 'Press any key to boot from CD/DVD drive...' with the dots counting down, press any key before the count down finishes. Assuming you get back to the Toshiba Recovery Utility menu, select the 'factory default' choice, and return your unit to its out-of-the-box state.
What F? Key do I press to restore my Fujitsu Siemens amilo L7320GW
Fujitsu simens back to factory settings
Downloads & Disks Regarding The Reset Factory Settings Fujitsu Amilo Li 2727
http://www.user-guides.co.uk/download/reset/resetfactory/reset-factory-settings-fujitsu-amilo-li-2727.html
Fujitsu Laptop to Factory Settings
Restoring the factory settings on your Fujitsu laptop is a great way to get rid of files associated with programs that have been removed from your computer that are taking up space and get rid of pesky viruses that you can't remove from your machine by any other means.
Restoring the factory settings on your laptop can also help resolve problems with an unstable laptop.
You should also restore the factory settings on your laptop if you plan on selling it or giving it to a family member or friend.
Restart or turn on your Fujitsu laptop. Press "F12" repeatedly when the Fujitsu logo appears on the screen to be redirected to the Boot Menu.
Highlight "Recovery and Utility" using the arrow keys on the keyboard, then press "Enter."
A progress bar will appear at the bottom of the screen while the computer is loading the recovery files.
When the files have been loaded, the System Recovery Options window will be displayed.
Select a keyboard layout, then click "Next." The Operating System dialog box appears.
Choose "Use recovery tools...," then click "Next." If prompted, type your administrator password, then press "OK." The System Recovery Options window will appear again.
Select the "Recovery" tab, then click "Restoring the Factory Image (only C:\drive)."
The restoration process will begin, and the laptop will be restored to its original factory settings.
When the process is complete, the computer will automatically restart and boot up to the Windows Setup screen.
Begin personalizing your copy of Windows.
Using Boot Disc
Highlight "CD/DVD" using the arrow keys, then press "Enter."
Place the boot disc that came with your Fujitsu laptop in the optical drive, then click "OK."
A progress bar will appear at the bottom of the screen while the computer is loading the recovery files. When the files have been loaded, the System Recovery Options window will be displayed.
Click "Next" when the Operating System dialog box appears.
If prompted, type your administrator password, then select "OK."
Click "Recovery and Utility" when the System Recovery Options window opens, then select the "Recovery" tab.
Click "Restoring the Factory Image (only C: drive)."
When the process is complete, the computer will automatically restart and boot up to the Windows Setup screen. Begin personalizing your copy of Windows.
Saving and recovering your factory and system images.
http://solutions.us.fujitsu.com/www/content/pdf/SupportGuides/HDD Restore Generic-Multi-lang B6FJ-3031-03EN-00.pdf
My computer doesnt show the factory reset
The only factory reset on a computer is in the BIOS, which you select after it shows the manufacturers logo or name. It will usually display the key to press and say SETUP. On Dell is F2, some are the Delete key.
Windows 8 will also do a factory reset which will pretty much do a clean install like when it was first installed.
If you do a reset on the BIOS and your Windows does not come up and possible blue screens with a STOP error, go back into the BIOS and on the drive type, switch it from AHCI to ATA. It should then boot fine.
3helpful
3answers
Need to reboot my dell optiplex 330 to factory settings
If you wish to restore your computer's factory settings, you need to back up you computer first.
Here is a link from Dell on how to reset your Dell's to it's factory settings.
All the best!
I turn on my computer and i get a dell start up screen. and in the bottom right hand corner it says press f2 for setup or f12 for boot options.. then it goes to a black screen that says "media test...
Hi. Try these simple steps: Restart your computer and press F8 when you see the Dell Screen. In the advanced Windows Option, choose Last Know-Good Configuration and press Enter. If nothing happens and you didn't boot to windows, you may need to reset the system back to factory image.
To do that, Do the first 2 steps if you're using Vista. If you're using Windows XP, on the Dell logo, Press Ctrl+F11 to boot from the recovery partition. Follow the instructions to recover system back to factory image.
Hope it helps!
^_^
2helpful
How do I reset my Gateway LT20 Netbook Series back to the factory settings?
Very simple! You need to go into Cmos for the setup which is usualy F2 on boot. Once in the setup you go to the end page whwere it asks you if you want to restore factory defaults. Simply click on it then press save and exit. If F2 does not work on the boot to access Cmos setup then look at the screen as it starts to boot and it will usualy tell you what function key is for setup. Good luck Phil
1helpful
Asus EEE PC 900A Linux- boot problem after downloading updates
Consider downloading a specific release of Ubuntu; eeebuntu. Download the ISO and then conenct an external DVD device to it, during the BIOS screen, choose the ESC button and boot from the external device.
This Ubuntu-specific group offers three kinds of ISO's (simple, super basic, and a loaded release), all of which allow all parts to work out of the box:
http://www.eeebuntu.org/
If this does not work, check the informal eeepc forums
http://forum.eeeuser.com/
Computer restarts by itself continuously and does not boot up completely
hi im wesley. ok to restore to factory settings go to your bios witch is when you boot up and press delete to enter setup thwn at the bottom of the screen it will say like F5 for default settings press that button and it will reset if it doesnt work open the computer up and take the power out and take the battery out for bout 10 minutes and then place it back in along with the power and it will reset. you might have to format your hard drive because it might be a virus that keeps rebooting your computer i had the same problem once.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
