20 Most Recent
ASUS Eee PC 900 Notebook Questions & Answers
WiFi not working...Function F2 is not turning WiFi
Sounds like the internal wireless card my have gone bad.They tend to do that from heat exposure.You can try uninstalling the card then rebooting, to maybe see if it will bring your wireless back to functioning.If your f2 key stopped working and it was at the time the wireless was turned off, this may also help.A bad wireless card can also effect other components attached to the motherboard as well.Its either a keyboard malfunction or most likely the card has gone bad.Hope this helps a little.Thanks
I CAN NOT LOG ON TO MY ASUS Eee 900HA WINDOW ,I
If you have a Windows password reset disk, you can easily reset your Windows password with it. If not, you can follow the steps to create one. You just need an available computer linked to the Internet.
Step 1: Download and install Windows Password Breaker with the available computer.
Step 2: Run the program and burn a Windows password reset disk. It could be burned onto a CD/DVD OR USB flash drive.
Step 3: Turn to your locked computer, insert the newly created CD or USB to your drive. Reboot the Computer and reset the Windows password.
It is easy and safe to use.
Some keys won't work
(1) check Fn key is locked- by holding fn key and hitting scroll lock or num lock
(2) Try to restart the computer in safe mode. It may work
(3) Take the computer to a previous restore point
Thanks
Why don't i have the extend desktop option
According to Intel, your GPU does not support an independent display configuration without an ADD2 card. See here:
http://www.intel.com/products/chipsets/gma900/
As far as I have noted, your motherboard unfortunately does not have that particular slot.
There is another option. You can always try a USB display adapter. The performance isn't wonderful, but depending on what you need it for, it may do the trick.
Hope this helps.
N40bers 36c2
Easy go to bios sytem push del keyb or F2 wen prompt are begin and then inside the bios system diseable the keyboard on wen windows begin in advanced options or wen the windows are begin touch the caps look keyb in yor keyboard that's all enjoid it please coment !
Having trouble starting it up.
ok check your charger to see if the light is on if not that is the problem try changing the fuse in the plug.
or replace the charger.
take out the battery plug in the charger try to boot up if it works its the battery.
falling that you may have a loose connection on you DC jack replace it this is a problem im coming across more and more DC jack replacement is not that cheap find a local engineer he/she will do it for a fraction of the price compared to pc world.
