I have just reset my telefunken TLEDDS 55FHD and now the colour has changed how do I fix that
When you reset your Telefunken TLEDDS 55FHD, the TV's picture settings may have been reset to their default values. This could be the reason why the colors on your TV may have changed. To fix this, you can try the following steps:
Go to the TV's settings menu: Press the "Menu" button on your remote control and navigate to the "Picture" or "Display" settings.
Adjust the color settings: Look for options such as "Color Temperature," "Color Saturation," "Tint," and "Sharpness." Adjust these settings until you achieve the desired color output.
Use a calibration tool: If you have a calibration tool, you can use it to calibrate your TV's color settings to your liking.
Perform a factory reset: If you have tried the above steps and the color output is still not satisfactory, you can perform a factory reset. However, note that this will erase all your settings, and you will have to set up your TV from scratch.
If none of these steps work, you may need to contact Telefunken's customer support or take your TV to a repair center for further assistance.
