My mitsubishi wd-65c8 has a
Common Repairs
For the following models: WD-52631, WD-57731, WD-65731, WD-Y57, WD-Y65, WD-57732, WD-65732, WD-57831, WD-65831, the most common repair problem stems from television shutting off almost immediately after it has been turned on accompanied by the message, "TV will shut down in a few seconds. Please check if the air flow is blocked." According to the Mitsubishi website, this issue is caused by a loose connection as a result of a faulty thermal sensor. For models: WD-73727, WD-73827, WD-73927, WD-73732, WD-7383, the most encountered repair problem has been in relation to the optical engine. Another common situation consumers have encountered is failure of the TV to turn on along with unceasing flashing of the green power light. The solution for this problem, caused by the DM board, will vary by repairman. Consumers have also encountered issues with moving vertical or horizontal lines appearing on the screen which can either be due to problems with the capacitor, light engine, or formatter board. Make sure all bad caps are changed.
