Put in a new stereo yesterday and found that the gray wire on the factory harness is broke, also the illuminated dash below stereo not working because of this. I connected the gray to the constant yellow(only way I could make it work.) and the two reds and the blacks to see if it had power, no power. When I connect new unit to battery it works and their are no fuses blown. Am I wrong in thinking the ground wire is black? would like specific wiring diagram for 2004 4runner with JBL system; btw do have a metra amp bypass 70-8117 connected
It appears that red is a speaker connection and not power. The complete wiring diagram I'd in the link below.
speaker wire color Toyota 4Runner Forum Largest 4Runner Forum
SOURCE: Im installing a
There may be extra wires you don't need. The basic set of wires on the radio is 4 pairs of colored wires--one black-striped and one plain for each speaker. Yellow is usually accessory power, red is hot, and black is ground. Some additional wires may be one for a power antenna, one for an external amplifyer, and one for facelight (in case it will run on dimmer)
The car should have the following corresponding wires:
Radio 12v--- orange
Radio Ground--- black
Radio Ignition--- yellow
Radio Illumination--- brown
Dimmer--- gray
Power Antenna--- pink (if you have one)
LF Speaker +/- tan - grey
RF Speaker +/- lt green - dk green
LR Speaker +/- brown - yellow
RR Speaker +/- dk. blue- lt. blue
The car or radio could have additional connectors, such as for a subwoofer, CD changer, etc.
SOURCE: stereo wiring 98 saturn
That stereo is now most likely dead. speaker wires are mostly green/black stripe, white/b s, grey/b s and violet/b s. ground is black and power are red and yellow.
SOURCE: 2002 solara amp, does it need bypassing?
Yes, it will sound horrible. like a opera on full treble sung by a mouse if it works at all.
2006 Toyota Camry Car Audio Wire Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Pink/Blue
Car Stereo Amplifier Location: Located to the right of the glovebox behind the passenger side of the dash.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Left Front Tweeter: Powered by the same wires as the left front speaker.
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Right Front Tweeter: Powered by the same wires as the right front speaker.
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
