Here's my online guide for using the Kirby shampooer.... HOPE IT HELPS!! Marci
I'm hoping you are online now, but more than likely you are not. I can not figure out how to attach the hose to my kirby shampooer. everything is attached with the exception of the hose. If I attach the hose to the tray, it will just shoot the shampoo contents into a small (size of the circular tube) line. Is that how it should work? I wish there was a visual diagram. I work much better seeing than reading.
Thanks for your help.
C
Try this solution for the G4, method is the similar for other models.
http://www.fixya.com/support/t524624-put_together
In regards to "Solution #3" which was more of a question.
The hose will just "squeeze in" to the shampoo tray and the shampoo mixer. Make sure the sponge is properly seated in the mixing bin.
Set your vacuum height to the very bottom, or one click up and instead of a small line, the solution will be dispersed the width of the shampoo brush roller
Http://www.goodvac.com/Articles.asp?ID=153
For visual people this is a good site for how to use the Kirby Shampooer. Make sure that you do not loose the "Sud screen" in step 8, without this you will not have foam. Turn on to put foam on floor, turn off to scrub and return foam to catching tray. If you place in between On and Off you can stretch out the amount of suds.
My Kirby disperses more suds when pulled back. Let dry, and vacume. If you do not vacuum completely, the residue of foam will attract dirt, and you will have a sticky feeling to your carpet.
Hope this helps.
SOURCE: Kirby sweeper shampooer attachment HOW TO use it
Please follw this link to view my carpet shampooing guide. Hope it is helpful!! :0) Marci
SOURCE: shampooer instructions
Here is a step-by-step guide to help you out!!
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
Hope this helps,
Marci
Marci
Unable to locate Kirby g model shampooer instructions on line.
i cant figure out how to put my shampooer on
Need instructions on using the shampooer
kirby ultimate g bagged upright vacuum
trying to assembel carpet fluffer
could someone tell me how to use the shampooer
need instruction for shampooer
need to know how to shampoo rug
I have not used my shampooer and i have had my sweeper for years i dont know how to hook up the shampooer any ideas
we do not have instructions!!!!!!!!!!!!!!!!!
I'm looking for the instructions too!!!
thanks
[email protected]
How to use the kirby carpet shampoo sysmtem.
i have a kurby and i want to use the shampooer i cant remember from when they showed me
