After replacing the cyan cartridge in my Canon MP610 all colors are printed in horizontal lines only. I cleaned the printerhead with warm eater during 8 hours. No result. Can anybody give any suggestion?
SOURCE: blurred printing printer i255
Hi, check the nozzle and test , if the result not in solid color there are spaces within the color means need head cleaning after head cleaning twice test print .
SOURCE: Horizontal colored lines through grayscale printed photos
Hi George,
It sound's like an ink-feed issue:
1) Dirty heads, even after cleaning
2) No-ink or poor quality ink
3) Damaged head: some are part of the cartridge, some are not
4) Air bubbles in ink
The test page is typically not as hi-res nor as saturated as a
photo print. The hi-res photo puts the greatest demand on the print head.
The color lines you see are actually lines of missing color,
where the head has failed to deposit ink, so one or two primary
colors are missing from the complete picture.
For example missing yellow will make a blue line.
Missing magenta will make a green line
Missing cyan will make a red line.... etc..
Clean the heads again and again, print again and again,
hoping to flush the system.
BUT, keep in mind that cleaning wastes huge amounts of
ink and tiny little cartridges of ink cost more than many new printers.
Martin
SOURCE: MP830 Cyan Ink won't print
To Fix the stupid Cyan, just unplug the printer, it may take more that one time unplug, its stupid problem, printer needs to reset, I have a full ink of Cyan but it says this "There is more than one Cyan" on the dispaly on the printer, and windows that its missing. I don't know what idiots programmed the printer. but screw them.
for cool stuff check out my site http://www.gagla.com
SOURCE: smeared lines
Okay, this was the problem I posted a few days ago. It's fixed now, so in case you have the same problem with smearing, here's what the help desk from Canon suggested: Open the cover and remove the ink cartridges. There is a gray lever in front of the cartridges. Lift this lever and the printhead can be easily removed.
Our printhead had a buildup of black ink on the surface. I carefully removed this with rubbing alcohol. I let the printhead dry and replaced everything. No more smearing. Imagine a help-desk that actually helped!
SOURCE: Canon MP800 Not recognising Ink Cartridges Magenta and Cyan
1.
Clean The Print Head Nozzles (Mac OS X) MP500 / MP800
2.
Clean The Print Head Nozzles (Windows) MP500 / MP800
3.
Confirm that the recommended ink tanks are installed properly MP500 / MP800
4.
Install recommended ink tanks in the correct order MP500 / MP530 / MP800 / MP800R / MP830
5.
Perform A Manual Print Head Alignment (Mac OS X) MP500 / MP800 / MP950
6.
Perform A Manual Print Head Alignment (Windows) MP500 / MP800 / MP950
7.
Perform the print head cleaning procedure on MP500 / MP800
8.
Print Head Alignment MP500 / MP800 / MP950
9.
Remove tape from the MP500 / MP800 ink tank
10.
Replace ink tank(s) MP500 / MP800
I hope it helps!!!
