SOURCE: Jura Capressa E9 Leaking
Your spout is probly cracked (a common problem). It won't hurt the machine if you want to live with making one cup at a time to catch it all.
If you want to get it repaired go to www.hotncold.com Click on Jura Repair for shipping instructions. We can turn the job around in 24 hours. The repair will also include a free software update.
SOURCE: leaks at the hot water spout during coffee brew
I had the same problem. I ended up taking the coffee machine apart and found that the reason coffee trickles out around the hot water spout is that the two coffee nozzles were partially plugged. Since I Had parts of the coffee machine apart I was able to clean it easily. It may also be possible to clean the assembly using a pick of some sort and clean out the holes of the two normal coffee spouts. Inside it is just a open cavity so gentle poking around and using some steaming hot water may do the trick.
If you want to take the machine apart you need to do the following:
1) take of the warmer plate on the top - 2 storz screws but an allen key works as well
2) take off the top plate of the machine - another 4 or 5 screws - make sure you empty the beans first otherwise you will have a mess
3) remove one screw from the right hand side of the removable coffee ground tray. Once this screw is removed the front panel is free to swing open except for the pipes connecting the front
4) unclip the steam assembly - there are a couple of plastic catches on the top. this will free the steam assembly from the front panel and also free a pipe connections. The steam dispenser pipe will also come free from the steam assembly.
5) remove the coffee pipes from the up and down sliding coffee dispenser. This is a small whitish color clip with 2 pipes connecting into it. The white clip has a little plastic catch on the top that frees it. The front panel should now swing open freely.
6) remove the sliding coffee dispenser from the front door. There are 4 plastic catches, 2 on either side. the whole front sliding coffee displenser now comes free
7) Take the sliding dispenser apart by release the 4 plastic catches on the front curved planel.
8) Inside the sliding dispenser is a white plastic piece that connected to the piping released in step 5. There is a small plastic catch that needs to be pressed while pulling fairly hard on the plastic piece and bending the whole piece.
9) You will now see the plugged spouts.
It goes back together really easily.
SOURCE: Coffee leaking onto to counter top
I've worked on that problem on a X9, I am not sure if the coffee/milk spout is the same but, I had to dismantle the spout and clean inserts, I also had to replace the o-rings on the spouts.
SOURCE: Jura z5 after filling system said coffee ready
Someone online sells a special screwdriver head used to open the Z5. With it, it's possible to take the machine apart, clean up the coffee ground dust that gums up the moving parts. You can giggle sensor switches that get stuck. The water lines will need decalcifying eventually, even if you use the the Clearyl water filter cartridges. If you're not up to taking machines apart, sell me your broken Z5: [email protected]
SOURCE: Machine leaks, but not in the area where coffee is
It sounds like it may be the Diaphragm pump controls for the law including seals. The diaphragm control is located on the pump output and adjusts the line pressure, thus the water flow more even and the pump noise quieter. It is in the front right hand corner of the machine. It could also be the hose or gasket that goes into the pump diaphragm. I would start with the diaphragm pump control unit as the seals can degrade after some time.
You can order the item form: http://www.juraprofi.de/Jura-Ersatzteile/Pumpe-Fluidsystem/Membranregler-fuer-die-Jura-Pumpe-inkl-Dichtungen::2896.html it is in German so use Google translate if you are having trouble reading the page. Hope this helps. I had a similar problem. Happy holidays.
