20 Most Recent Jura Capresso Impressa S8 Coffee Maker, Espresso Machine Questions & Answers
I just called Jura support and they talked me through this SIMPLE solution and it worked right away. Change the grind setting *while the grinder is a spinning*. If you don’t do it while its spinning nothing will happen.
Don’t hesitate to call Jura - their support team is very good.
800 220 5701
Jura Capresso... | Answered on Nov 10, 2018
I had a similar problem. I always religiously cleaned the machine when prompted but nonetheless I reached a point where coffee quit coming out of one nozzle. I tried the suggestion to stick a wire up the nozzle to dislodge any residue that was blocking the water. That helped a little and then it did not next time. So I USED A DENTAL WATER PICK on both nozzles and that cleared up the problem completely. MUCH BETTER than wire or paperclip.
Jura Capresso... | Answered on Nov 09, 2016
Once coffee is extracted, its passage from the brew group to the cup is a simple gravity flow. There is no pressure to push its flow.
Layers of dried coffee clog the passage. In your machine this is advanced clogging or the water is not passing through the coffee and being drained into the tray.
To prevent this, use rinse cycle every day after coffee making is completed.
Descale the machine using Manual descaling method.
Do not use Filter cartridges as the same are expensive & ineffective.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
Jura Capresso... | Answered on Oct 23, 2016
This error is because:
1- Flow meter is blocked & not sending signal of water flow.
2- Entire hydraulic system is filled with Calcium deposits and slowed down flow of water.
Solution:
1- Open the machine and manually clean flow meter. It is located between the water tank & the pump.
2- Follow this by manually descaling the machine. Seelink. Do not use automatic descaling method suggested by Jura.
Stop using Filter cartridges as the machine reminders for descaling are silenced by use of filters. Services Unlimited Inc Parts Guru Since 1988
All Jura machines in the series C, E, F, J, S & Z models have the same problem. The Jura recommended maintenance is insufficient or erroneous:
1- When new machine is set up, the owners click OK for use of Filter cartridges. This helps only to display reminders for replacing the filter.
2- The instruction also advises, regular use of Filters, eliminates descaling the machine. That is not accurate. Reminders for descaling are delayed or eliminated. This allows accumulation of Calcium deposits in the entire hydraulic and coffee system.
3- Cleaning tables recommended & sold by Jura do not remove Calcium deposits in the coffee/water passages. The automatic descaling method recommended by Jura also leaves the coffee side of the machine unclean. The error message in your machine is due to Calcium deposits in the Brew group, coffee outlet & the faucet dispensing coffee in the cup. I suggest all Jura machine owners should manually descale machine. Manually descaling includes use of 6 to 10 rinse cycles with descaling solution in the water tank. The error message "Clean Machine" is accurate & pointing to descaling the Brew group, coffee outlet tube and coffee dispensing faucet by using rinse cycles.
After the rinse cycles are complete, refill Descaling solution & continue descaling the rest of the machine using hot water dispensing function, until the tank is empty. Finally, give a final flushing of machine to flush out remaining descaling solution inside the machine.
SENT IT TO FACTORY FOR REPAIR.
Jura Capresso... | Answered on Jan 05, 2016
Hi, I made a video how to fix your Jura step by step, good luck... http://fixandparts.wix.com/nicknicoloudis#!jura-coffee-machine/c15gy
Jura Capresso... | Answered on Mar 23, 2015
Hi Mark,
I can not this machine mark, but on other machines it can hang in system and then we have to start the programme again.
Sorry i not can give you a clear solution on this case:-(
Best regards
/Mirran
Jura Capresso... | Answered on Oct 08, 2014
You can check the water valve, it may become clogged. But you should not disassemble machine if you are not specialist. Contact Jura service center if your machine still under warranty.
Jura Capresso... | Answered on Sep 25, 2013
Jura Capresso Impressa S8 Coffee Maker, Espresso Machine Logo
57 questions posted
Top Jura Capresso Coffee Makers & Espresso Machines Experts
markybean
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Impressa Jura Capresso
  • Impressa Jura Capresso
Most Popular Question
jura capresso model
  • Coffee Makers & Espresso Machines
