Can't print mesage unable to clean 5a
Sir/Madam
If one of the following messages is displayed on Your Printer,I suggest You Go To Below Official Brother Website For Troubleshooting,
http://welcome.solutions.brother.com/BSC/public/as/sg/en/faq/faq/000000/000500/000065/faq000565_012.html?reg=as&c=sg&lang=en&prod=mfc290c_all
Or If You FaceProble Then Follows Us On For Online
Brother Printer Support
SOURCE: Brother MFC-465CN says 'Unable to Print 5A'
Hi there
Solution:
· Machine off
· Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
· Press 80
· Press the “mono start” button several times until you see “purge: xxxx”
· Press “2783” in order to reset the purge counter. You will see: “purge:0000”
· Press the "stop" button.
· Press “99” to exit the maintenance mode.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
SOURCE: Unable to print and showing an 'unable to print 5A code
There are diffrent reasons for this error:
check, if something sticks in the machine (paper or metal clip)
The paperfeeder clutch gear is broken: check if the paper feeder works well.
The purge station has problems to do the cleaning jobs: gear broken or too much ink within the purge tubes.
Anyway, this problem is hard to handle for a novice due to so many diffrent reasons.
You should contact a service dealer and in case it is still in warranty let fix them.
SOURCE: problem printing unable to print 5A will not go away
Hello we went into the internet and they are all Junk from what we see.We had a MFC-4420C Before and it has a code 41 and all brother does is keep sending you refurbished printers back and forth so you have no warranty at all the warranty starts at the time you buy the first one so that is what happens.So beware anyone with Brother printers with these models. They are both Junk and you will just lose your money.
SOURCE: What could the error code "Unable to print 5A"
This link has the Brother Error Codes...
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000100/000068/faq000168_005.html?reg=us&c=us&lang=en&prod=mfc6490cw_all&Cat=11
