20 Most Recent Brother MFC-3240C All-In-One InkJet Printer Questions & Answers
Change LCD language to English on Brother MFC-3240C
Gud Day!
Power on your printer. Press the menu of your printer then sect the arrow down or up to select the language menu. press ok if u have seen language then go to option select from german to english.
Please rate the solution after you have tried it so that I can assess you more on this problem.
Jonags
2/2/2022 7:21:55 PM • Brother... • Answered on Feb 02, 2022
2answers
Unable to print
Brother Error Codes
RAM clear (most models)
Quickly press function * 2 8 6 4
Display should read maintenance
Press 0 1 for a full ram clear, or 9 1 to retain user data
Display should read reinit for a few moments then redisplay maintenance
Press 9 9 to exit the maintenance mode
Other maintenance mode switches:
01 ram clear (see 91 below)
02 scanner initialize (feed a white sheet, then a black sheet)
05 white level
09 print test
10 modify soft switches
11 print configuration list
16 panel test
19 CML test
20 signal test
21 tonal test
23 filter RX
54 scan edge
55 scanner area
66 test print memo
75 display drum life (if enabled on laser models)
76 reset drum life counter (laser models)
91 parameter initialize (user programming remains intact)
95 protection
B2 error = scanner or power supply error
Brother 950/980: On copy or transmit they may produce black pages. Prone to bad scanner (CCD). Brother may provide a replacement CCD at no charge to the original owner. Sometimes leaving the unit unplugged for a few hours will solve the problem temporarily.
Brother HL600 series laser printer toner will work in the laser fax & multifunction machines (part number TN100HL = TN100PPF). Drum units may be interchangeable as well (?).
Brother 1350/1550/1950: Problem: Record paper jams. Solution: Replace upper shoot. P/N UF6058001. Although there seems to be nothing causing the jam, the upper shoot gets stress marks on the ends. Replace even though it is not broken. (Thank you David Price, [email protected])
Thermal Transfer Machines: Only one side of the page is printing. Caused by the printhead latch being cracked. The latch is blue in color there is one on each side of the printhead, replace both latches
11/12/2021 5:48:49 PM • Brother... • Answered on Nov 12, 2021
Unable to clean, error 5A. Already reset purge
Hi Jason, 5A is usually caused by a bad maintenance unit. The purge cam gear may be broken or too much load on the maintenance unit. Either way replacing maintenance unit should solve the problem.
7/31/2021 11:03:30 AM • Brother... • Answered on Jul 31, 2021
Brothers error message 50
Check for remaining ( small peace) jammed paper inside.
2/11/2021 6:54:09 PM • Brother... • Answered on Feb 11, 2021
Won't print. says no magenta cartridge installed.
It seems simple enough, but this is one of the most effective ways of fixing printer cartridge error. Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached.
To reattach the cartridge check the following steps :
turn on the lid of the printer and then remove the cartridge from the printer head.
Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report.
Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
6/9/2018 4:20:15 AM • Brother... • Answered on Jun 09, 2018
Brother 3240c Error A1 ,A2 and 82
Not sure what 82 code is but A2 and A1 have to do with size of paper possible original to long for size of paper in cassette
3/28/2017 8:03:06 PM • Brother... • Answered on Mar 28, 2017
2answers
Brother ink monitor not working
There could be a posibility that you may be low on ink. The reason i say this is that you say it prints green. Green is blue and yellow. That means that your red is empty or dried out. If you are low on ink you will have a low or no ink indication and sometimes the software for the printer only has 3-5 diffrent indications.What i mean is when you see the data for your ink there are diffrent levels that it shows. Your software may not be able to diffrenciate between the colors just the status of say one color in your case it could be red.Therefore it would read 0% of ink avaliable but still be able print green. If i were you I would buy a new ink cartridge and see if you get the same results.
3/27/2017 11:25:33 PM • Brother... • Answered on Mar 27, 2017
2answers
My paper keeps jaming
paper keeps jaming - Brother MFC-3240C All-In-One InkJet Printer
8/3/2016 5:55:40 PM • Brother... • Answered on Aug 03, 2016
3answers
Brother MFC 3240C replace black ink
6/30/2016 8:32:11 PM • Brother... • Answered on Jun 30, 2016
2answers
Clear Paper Jam error -- but there is no paper jam!
yyyy
10/23/2015 12:11:19 PM • Brother... • Answered on Oct 23, 2015
2answers
Brother's MFC-3240C All-In-One
I do not know if Windows Vista driver software for the MFC-3240C is available on CD/DVD.
You can download either the Full Driver & Software Package or the Add Printer Driver Wizard for Windows Vista ("regular" edition) from this page.
You can download either the Full Driver & Software Package or the Add Printer Driver Wizard for Windows Vista x64 Edition from this page.
4/29/2015 9:09:47 AM • Brother... • Answered on Apr 29, 2015
How can i change the lcd language to english on brother dcp 195c
hi, i normally do not work on ink jets anymore. this may be simple. find the "menu" button push "menu"then "0" then "0" it should show you a language list select your language. push "ok"..done
6/7/2014 5:03:36 PM • Brother... • Answered on Jun 07, 2014
0answers
Brother MFC-3240C All-In-One InkJet Printer Logo
270 questions posted
Norman Weimar
Norman Weimar
k24674
View Most Popular
MFC Brother
  • MFC Brother
Most Popular Question
unable clean error 5a already reset
  • Office Equipment & Supplies
