SOURCE: hotpoint bwm129 gets stuck mid cycle and dial does not move round
YOU NEED TO ESTABLISH IF YOU ARE USING A HOT CYCLE IF THAT IS SO YOU MIGHT HAVE E PROBLEM WHERE THE ELEMENT IS NOT COMING ON THEREFORE THE THERMOSTAT WILL NOT FUNCTION RESULTING IN THE TIMER REMAINING STILL.YOU NEED TO CHECK THE ELEMENT IF THATS THE CASE.IF YOU ARE USING THE COLD CYCLE AND IT IS STUCK ON THE SAME POSITION FOR A LONG TIME YOU MIGHT HAVE A FAULTY TIMER BEST YOU HAVE IT REPLACED IF THAT IS THE CAUSE.LET ME NO IF YOU NEED ANY MORE ASSISTANCE.GOODLUCK.MOHAMED
SOURCE: hotpoint first edition takes in water but does not wash
Could possibly be a broken drive belt to the motor or motor brushes may need replacing.
SOURCE: i have a hotpoint bwm 129. clothes arnt coming out
is it rinsing okay is it pumping ok if not clean filter located at sump hose
I use to hhave to do that my was filter was blocked
