20 Most Recent Hotpoint BWM12 Front Load Washer Questions & Answers
You should be able to drain the water out by laying the drain hose down into a bowl. Does the pump function properly on final spin, that usually clears the water to allow the door to open. Parts are obtainable from Hotpoint Spares.co.uk.
Hotpoint BWM12... | Answered on Jan 30, 2015
Try pushing the door in as I suspect the door interlock switch is stuck, if this dosen't work you will have to replace the door interlock switch which can be purchased from Hotpointspares.co.uk and is reasonably easy to fit as can be seen on YouTube .
Hotpoint BWM12... | Answered on Oct 24, 2014
unless you can plug the leak
its a complete drum
Hotpoint BWM12... | Answered on Mar 13, 2014
Generally the problem lies with a faulty door interlock switch rather than a programmer fault. These are can be purchased easily but don't be fooled into buying cheap alternatives, and if you are a competant diy person no problem to fit.
Hotpoint BWM12... | Answered on Mar 07, 2014
The flashing lights means that an error had been detected.
The machine must be unplugged from main to check the drain hose and the drain pump.
The most common is that the drain pump is clogged with debris and must be unlocked.
Hotpoint BWM12... | Answered on Nov 24, 2011
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Hotpoint BWM12... | Answered on Jun 26, 2011
Hotpoint BWM12 Front Load Washer Logo
97 questions posted
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Hotpoint Washing Machines
Most Popular Question
hotpoint bwm12 door lock light not not
  • Washing Machines
