I use to be able to access my printer/copier/scanner on my computer to add e-mail addresses. I can't now???
Self Help Product Support Konica Minolta Business Solutions Inc
try this site
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
SOURCE: Cannot scan to email Konica Minolta 250 Bizhub
To scan to email, Administrator email address must be set in the machine (any bogus email address will work too).
Also, email server address must be input as IP address if DNS or WINS is not running in LAN.
SOURCE: Scanner - adding new email address onto the system
Go to your web browser and type the IP address of the MFP.
There you will see a tab along the top where, when clicked will let you enter address into the address book.
The MFP MUST have the email set up first, just like a computer as far as domain servers and it also needs a valid email address to log on and send off the messages.
This can be done on the panel of the MFP or by logging out and then back in as the admin through the web browser again.
SOURCE: Bizhub 250 scan to email error
Change your account information from external to internal, i.e. yourmaildomain.com to yourADdomain.local. Change on the scan account as well as the email addresses.
