20 Most Recent
Toshiba E-STUDIO 450 Copier Questions & Answers
Estudio 450 admin password
Hi, Go to 08 mode. Enter 263 and press START. It will show the current password. To change press C to clear and enter the new password.
Error code f120
Hello
F120 error is Database Abnormality
Please switch off the machine
While holding down 0+8 buttons, switch the machine, when in test mode please input 684 and press the start button. that will rebuild the databases. Then input 690 and intialize the hard drive.
Good luck
C470
what your problem i cant understand is c470 OR e030
My Toshiba e-studio 45 displays
Hello
I encountered the same problem a few years back, I found the power supply to be faulty.
You can try checking all the fuses on the power supply.
Sorry that is all i have at the moment.
I will see if i can download the pcboard repair manual.
Please let me know where i can email it to.
Regards
Toshiba COPIERS - E-STUDIO 232 Copier bao loi c410
The problem is this :
Thermistor or heater abnormality at power-ON: Abnormality of service call the thermistor is detected when power is turned ON or the temperature of the fuser roller does not rise in a specified period of time after power is turned ON.
the solution is to change thermistors
Network intializing
see if the DHPC is enabled if so disable and give the IP address in copier. and ping in run command type: ping ip address space and -t to be entered to get reply.
Toshiba estudio 450 Used toner cartridge is empty
Hello
You will have to remove the waste toner bottle, put some cleaning solvent in the bottle and wash the toner out of the bottle.
Please the bottle out to dry before you replace it in the machine.
Regards
Printer in not detecting network
Make sure your connecting wires are still connected and not loose. If you have a new network you will need to update it in the memory.
