20 Most Recent Konica Minolta DiALTA Di200 Copier Questions & Answers
Tray one lift motor is in-op or is stuck
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Konica Minolta... | Answered on Mar 25, 2018
cooling fan motor code, this motor/fan is located on the right side door behind the transfer assy. clean the fan unit, if its been to long might be burned out then replace it worse case the main board $$$$$$$$$$$$$$$$$ if you can find one;( a very legacy Minolta machine sorry
Konica Minolta... | Answered on Mar 10, 2018
Minolta copier show error code c0040. Please show me the picture that point of problem. The second problem. What is the way we could what kind of minolta di ...in the machine?thanks in advanced.
Konica Minolta... | Answered on Feb 28, 2018
Sir/Mam,
Power off the machine. Then remove the toner bottle, be careful the hole might be on the bottom and the toner is going to go everywhere. Then close the toner cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner bottle correctly. If THE KNUB on the side of the bottle is damage put a new one in. That KNUB is what the toner motor uses to turn the bottle, if it damaged you get a code. If that does not work, you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad.
Konica Minolta... | Answered on Feb 25, 2018
was the power on when you depressed the small switch? you mite have damage the lamp in the fuser or the control board. very old machine find the parts and replace them
Konica Minolta... | Answered on May 07, 2017
C500 is a fuser code, the hot part of the machine, the fuser fuses the toner to the paper, so that the toner does not smear off. But to solve this must have the model number. As each series of machine has a different way to reset machine
Konica Minolta... | Answered on Dec 11, 2016
Mam,
Open the front door lay down on the floor and look up at the section that is slanted (close to hinge side of the front door) Fine the small hole with the machine on, fine a small non metalic stick and in-cert into the small hole touching the small switch which will re-set the machine for C-0500 codes. Do this once if the code comes back replace the fuser, DO NOT RE-SET again messing with FUSER can catch on fire will ruin a perfectly good day.
Konica Minolta... | Answered on Jul 09, 2016
replace the developer and drum or the image unit as a whole
Konica Minolta... | Answered on Jul 06, 2016
English please
Konica Minolta... | Answered on Jul 03, 2016
Sir/Mam
First open the right side cover where the image unit is located. Check the two latches that latch the door ensure they are not broken, especially the rear one. Then get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel will go thru some screens when you see the screen with the copiers on it on the left side of the screen in the middle you will see a small "." When the dot appears touch 3 button. Then the machine will continue to the code screen. Press the Utility button you should see a new button "Maintenance Mode" touch it then touch trouble reset. The machine will again go thru screens will see the"." again do nothing. Should go ready to Copy. If the code comes back do not reset, you are messing with the Fuser the Hot part. Continuing to reset without a technician looking at and or replacing it, the fuser can catch on fire and that would ruin a perfectly good day.
Konica Minolta... | Answered on Jun 27, 2016
large capacity draw check it
Konica Minolta... | Answered on Jun 26, 2016
no such code for this machine
Konica Minolta... | Answered on Jun 25, 2016
one
Service mode, first
1.Press the Utility key.
2. Press the Meter Count key.
3. Press the following keys in this order:
Stop  0  0  Stop  0  1
for security "Stop 9"
In Security, Select Copy Kit
1. Touch "Set."
2. Press the Clear key to clear the current setting.
If the setting is accidentally cleared, press the Interrupt key to
undo the clearing operation.
3. Enter the desired value from the 10-Key Pad.
4. Touch "Current."
5. Press the Clear key to clear the current value.
If the current value is accidentally cleared, press the Interrupt key
to undo the clearing operation.
replace the panel
Konica Minolta DiALTA Di200 Copier Logo
351 questions posted
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Konica Minolta Office Equipment & Supplies
Most Popular Question
c004c
  • Office Equipment & Supplies
