After the wash cycle has completed, water leaks into the drum (though it doesn't seem to happen all the time) and usually ends up pooling at the bottom, soaking the clothes and requiring another spin cycle to remove the water and get the clothes dry enough to place them in the dryer above
SOURCE: Washer spins but not enough to extract water from clothes or tub.
it sound to me to be the water pump, with all the water in the tub, the machine dont spin ok, and the water is extracted by centifugal force, not by pumping as it should be, call a tech, this is a hard job for regular people..good luck
SOURCE: water not draining completely after cycle ends
First of all, is your drain hose connected to a kitchen sink or into a standpipe? If its a sink make sure you form a loop or curve in the hose as high as possible above the sinks own waste(plug hole) ,to ensure water cannot travel from sink back into machine. If this is not the case then your water pump, or the rubber pipe coming to the pump has definately got some kind of obstruction inside. Your washing machine has not emptied properly since it filled up at the beginning of the cycle,and has not got rid of the soapy water enough to enable a true rinse.Hence the detergent smell on clothes... Turn off power at plug socket.Take drain hose out of stand-pipe (or connection to sink waste)and drop this hose into a washing up bowl or similar at floor level,to drain off as much water as possible before disconnecting hose to pump or checking the pumps impellar to discover the blockage..Lets know how u get on,good luck.
SOURCE: MAYTAG MAH6500AWW-WASHER WILL NOT AGITATE/SPIN
Check out the motor control board near the floor on the right side. These have a high failure rate on the Neptunes. Maytag redesigned both the motor and motor control board to be more reliable. While inspecting this board, you are looking for a blown 10 amp fuse and /or burnt components. If you have either... then you will need the the new 12002039 motor conversion kit which includes the motor, motor control board and the wire harness.
See http://www.neptunehelp.com/index_files/Page667.htm.
This kit takes about an hour to install.
Don't forget to replace your door latch wax motor. See www.neptunehelpsong.com to hear a funny song explaining the faulty door latch failure.
SOURCE: mle2000ayw Stackable washer/dryer not washing, spinning
If the door lock light is on then is might be the "door lock enable spin switch" the plunger at the opposite end from the wax motor is not fully depressing the switch. In the stackable it is just behing the door lock. Remove the two middle covers (2 white phillips screws and one hex head screw on the middle of lower cover by the wires)to test place a few layers of masking tape on the end of the plunger and cycle the machine. Might also be a weak Wax motor (dark brown in color) to be safe replace both for about $12 each. Fix in 10 - 15 min.
SOURCE: Maytag Neptune Error COde "nd"
This is now the 3rd time this has happened. The 1st 2 times it cost me ~$100 to have a technician come in and fix.
This time, I did it easily. For my Maytag Neptune washer, I removed the back panel (2 screws). On the bottom tray is the water discharge pump. On the output side of the pump there is a small cavity under the rubber flapper where a nickle fits perfectly. I removed the nickle, reattached the output drain line. started it up ...
and viola! the problem solved.
