I am trying to scan a document to my macbook, but the error message on the scanner reads ''Scan error. try scan from computer or see documentation.'' does anyone know how to solve this? the printer prints fine...
you can scan from the computer using hp solution center.look for it's icon on the desktop or on the laptop.double-click on that and it will give you scan options.you scan photos or documents using that program.
if you installed the software cd that came with the printer then you should be able to use solution center
Try using widows paint. Look in windows accessories off the start program menu. If you open windows paint, look for open file from "Scanner or Camera". Most likely you can get the scanner to work again in Vista. Otherwise...try Vuescan scanner software. I think you can get a free trial period online and it should also work. You'll have to pay for that if you like it.
Is it installed in windows as a scanner? Dont use scan button on machine try using scanners or document imaging software that needs to be in place on your computer, ie Document imaging in office or scanners and camera in windows, one sends scan signal from the PC, can use the scan button on scanner only when configued to do such. Scanner has software as does the printer both can found at HP web
you should look through the documentation that came with your scanner. The error message is probably telling you to read the documentation for troubleshooting why the scanner isn't working. Most documentation that comes with devices like that has a troubleshooint section that describes common problems.
Please check if the option cable connected on the back of the scanner is seated properly.
If you are using epson scan to scan from your computer, try to scan using either professional or home mode and choose the correct settings.
i have found the way to scan items from a Canon MX310 (on windows)
1.On windows go to control panel 2. click hardware and sounds 3. then hit devices and printers 4. then click on the Canon Inkjet MX310 seriers 5. then you will see scanner management click on scan Photos or docs 6.then place the photo or doc under the scanner and hit scan!
That is all the steps you will need. 17 years old computer tech.
