Re: not working, power is on but nothing is coming up in...
The embedded software on board is not booting up. It may have detected a hardware problem. Make sure the power supply is in good condition then disconnect everything else and try again. If fault remains, its toast.
Some kind of feedback perhaps? Are you using a multi core with sends & receive inside it but NOT individually screened? i.e. "pick up" inside the cable? Is it both speakers? Try them one at a time in case one is faulty but affecting the other? Unplug the input leads & see if the speakers by themselves are making any sound ( a small hiss?) If the speakers with no input (but powered :-) makes no whistle then it's coming from other gear...... Also the speakers may have switch mode power supplies & if you don't have a decent ground you could have problems. Make sure you have a good ground connection back to the fuse board. If you studio is in a shack at the end of the garden running on extension cords you may need a local connection to ground..... Good Luck!
what program are you running and did you set up your keyboard with the software so it can recognize it. Depending on what software it is your using as soon as I know I can tell you how to get it working. I use my midi keyboard with everything from reason, Ableton live, pro tools logic logic express vdj traktor basically every software!
Essentially you connect the power cord to power and connect outputs from say a mixer to the inputs using TRS balanced cables... and connect the outputs of the unit to your power amplifier.
Note taht there are MANY other possibilities using "inserts:on some devices.
