20 Most Recent
Roland GK3 Divided Guitar Pickup Questions & Answers
How to connect Gk3 equipped guitar to Electric Piano or Synthesiser ?
A Gk3 cannot be connected directly to an electric piano or synthesiser. The 23 pin DIN connector connects the GK3 / GUITAR to a Roland guitar synthesiser which produces the synth tones . This unit can be connected via midi cable to any external keyboard or synthesiser...to produce different or varied tones from the external synth ........provided the devices are able to communicate with each other...see the midi implementation charts for each device for information....
Hi. Can I use the second pedal on my Roland BK5 to scale up the key one semitone at a time?
Yes, you can use the second pedal on a Roland BK-5 keyboard to transpose the key of the music that you are playing up or down by a semitone at a time. To do this, you will need to press and hold the second pedal while playing the keyboard. You can also use the transpose function in the settings menu of the BK-5 to adjust the key of the music that you are playing by a specific number of semitones.
1/5/2023 4:04:49 PM •
Roland Music
Answered
on Jan 05, 2023
I need a circuit diagram for a Roland MA-15D speaker please?
It's a Chinese made Roland and no service information is available as when a fault is found the main board is replaced, eliminating the need for service information.
I would check that it is a stereo out jack and not mono. If it is a stereo out, check that both input phonos work. If they do, replace the faulty socket or damaged pcboard.
11/17/2022 6:14:26 PM •
Roland Music
Answered
on Nov 17, 2022
MY Roland Handsonic's digital display is gone
Hell,
there is no display on your Roland Handsonic because the screen inverter or screen board panel is faulty. This has to be replaced for you to see your digital display again.
So its either you use it like that without the display or you take it to a repairer for fixing.
Take care.
7/11/2022 8:54:01 AM •
Roland Music
Answered
on Jul 11, 2022
