Xerox WorkCentre 3325/DNI - Multifunction fax / copier / - 3325/DNI Logo
A
Anonymous Posted on Dec 03, 2013
I need some help printer says the port is not connected which it is...
Cannot get win XP to acknowledge that my bran new OffJet 6100 is connected with simple USB port. ( Had same problem with previous printer). HP said I now need to get a virtual printer port download fr
Are you doing this in a wireless situation?Can you connect with a cable and print.Have you gone to
Windows Logo
Control Panel
System and Security
System
Device Manager
Check there to see if you can see a printer port listed.
I need to connect my printer to my wireless router.
Assuming your printer is network compatible:
  • If it uses Wireless, use your printer's configuration to connect to the D-Link's network. You may also want to use the D-Link's built-in DHCP controls to assign a single IP to your printer for simpler setup
  • If it has an Ethernet port, connect a cable from the Printer's Ethernet port to one of the 4 ports on the back of the router. This should connect the two and all going well, most printers will sort themselves out from here.
If your printer is not network capable, you will have to connect the printer to a computer then use Windows sharing options to share that computer's printer with the network.
Hope this helps, Alistair
I eed to know which port to connect to to use usb
I had this problem as well. I loaded the drivers for the USB to Serial Adapter and the drivers for the SiPix printer, left the adapter cable plugged in and rebooted my pc. After powering my PC back up I went back into the SiPix printer properties and another com port (5) showed up in the list of com ports. This was the port I needed and the printer woks great!! now your comport may be different depending on which USB port you have your SiPix connected to. This worked for me. Hope it helps you out!!
1helpful
I cannot connect my printer to my computer it asks for a port? what do I need? where do I get it from and how do you connect it.
Hello there...
You locate your working usb ports and plug your usb printer cable in then turn the printer on. If that still doesn't help, post your reply here... have a nice day!
HP Deskjet 930C USB connection
Yes but you may have to re-install the software for the camera. If so,
Normal 0 Try disconnecting the Camera from the USB port and reinstall the CD software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Hope this helps. Bud
I need help with where you connect the printer to the computer
Depends on the printer. If it is a new computer, that it should be connected to the USB port. If its quite an old printer than it could be using a parallel port
Printer connection
Hi jatsen,
Please kindly specify what is the brand/model of your printer? Majority of printer it is being installed or connected with the following ports. USB, parallel  ports.
But you need to install the driver if doesn't support by your operating system.
Hope this will be helpful to you.
Best Regards,
Philip
1helpful
Problem connecting and printing my lx-300 matrix printer
You need to get a paralell to USB cable, like the one on the following link: http://catalog.belkin.com/IWCatProductPage.process?Product_Id=20651
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
