check the fans Turn off the laptop, close the lid, flip it upside down and rest it on a flat surface.
Locate the cooling fan, which is under the vents on the bottom of the laptop.
Spray the compressed air can inside the vents for 5 to 10 seconds.
Change the air direction until all the dust is cleared.
check you CPU make sure its securely seated and has thermal grease
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
hope this helps
